power window won't close all the way??
Old Feb 17, 2010 | 03:53 PM
pliskin8's Avatar
Icon3 power window won't close all the way??
the title says it all, the window does work it goes up and down but just does'nt close all the way, it gets stuck at a certain point and all you hear is this clicking sound from the (power window) motor. i took the door apart but everything seems to be in place. i uploaded a vid so you can get a better idea of what im talking about, any help would be appreciated.
http://www.youtube.com/watch?v=y8gjQ6V6qRw
Old Feb 17, 2010 | 08:26 PM
pliskin8's Avatar
Default Re: power window won't close all the way??
Old Feb 17, 2010 | 09:07 PM
Linked's Avatar
window may be off track, idk, but start with looking at the window assembly
Old Feb 18, 2010 | 12:48 PM
pliskin8's Avatar
nah, its not off track the window does go up and down like it normally would
Old Feb 18, 2010 | 02:01 PM
ifIexplode's Avatar
try spraying a silicone lubricant on all the rubber tracks. It works wonders.
Old Feb 19, 2010 | 07:17 PM
pliskin8's Avatar
i'll give it a try, hope it works
Old Feb 19, 2010 | 07:22 PM
em1effekt's Avatar
mine is doing the exact same thing but have no idea of what it could be...
let me know how it goes...
ill also let you know if i find out what it is..
Old Feb 19, 2010 | 07:23 PM
sbpphoenix's Avatar
it probably came off the rear track. you need to take the door panel off and see if the glass slipped out of the rubber. happened to me the other day.
Old Feb 19, 2010 | 07:30 PM
em1effekt's Avatar
i think mine may have fallen of the rear track because it moved a little to the front like towards the fender...so to roll it up it would have to go to the left and the go up....
but i can really see if his does that also..
Old Feb 19, 2010 | 09:03 PM
fryman's Avatar
Are you sure no teeth are missing from the window motor or regulator?
You should just take the door panel and rain guard off and press the button while you look in the door and you should be able to clearly see what the problem is.
You'll have to take that stuff off anyway probably so might as well.
Old Feb 19, 2010 | 09:35 PM
cilvia's Avatar
i had that EXACT same problem TWICE, and the last one several months ago...popped the door panels out and and pulled the regulator out and the teeth were all eating up...hoping it would go up will only eat the teeth up more ...if you need to close your window for the time being you could just help guide it up with one person hitting the roll up button and you forcing it up!! which i have done by myself with a marker and knee to roll up my window and my two palms to bring it up for a whole two weeks until i got it fixed...haha...a new window regulator solved all my issues and will cost you around 70 dollars at the dealership and its a simple fix!! causes from my experience seem to be from loosen bolts from the motor to regulator or something getting stuck in the guides where the window rolls up to in my case a piece from my weather techs =X
Old Feb 20, 2010 | 03:09 PM
pliskin8's Avatar
i was thinking that i would probably have to replace the regulator anyway, thanks for the input
Old Feb 23, 2010 | 05:39 AM
ducsays's Avatar
wat is the update on your situation? i have the same exact problem. havent taken out the motor yet but sounds like a regulator problem tho.
Old Feb 23, 2010 | 08:36 AM
420eg95's Avatar
yea its a regular problem for hondas, driver side more than passanger, I guess it gets more use than passanger side, but its the teeth on the window regulator getting worn down and eventually it will fail, all you need is the regulator, motor should still be good if you can hear it. I got the whole window regulator and motor off craigslist for $35 , but they sell new for about $60-$150 depending on the kit and brand.
Old Feb 23, 2010 | 10:53 AM
pliskin8's Avatar
i took the door apart and looked at the assembly but nothing seems wrong, so the only thing left to do is to replace the regulator
Old Feb 23, 2010 | 09:19 PM
ducsays's Avatar
yeah teeth is worn down.
Old Mar 18, 2010 | 09:15 PM
em1effekt's Avatar
did u ever get it done?
Old Mar 19, 2010 | 02:08 PM
pliskin8's Avatar
not yet. i already bought the regulator but i havent had time to install it (i have 2 jobs) looks like this coming week i'm gonna get some time to do it though, i'll keep you posted
Old Mar 24, 2010 | 10:46 PM
B16Power's Avatar
I have the same problem with my driver side. I however replaced the regulators about a year ago so I'm thinking the teeth in the motor has gone. Has anyone heard of the teeth in the motor going causing it to do this? When I roll the window up it makes two loud pops and sometimes at the point it usually pops it stops and grinds, when I took the window or when I assisted pulling up on the window while rolling up it doesn't do it so it's like it only does it while there is a load on the regulator.
Old May 25, 2010 | 08:01 PM
Koixlove's Avatar
This was such a great help for me.
I have the same problem with my driver's side window not completely closing
but with the motor still working.
Now that I checked everything out recommended,
its the regulator's teeth that are worn down!
THANK YOU ALL!
Old May 26, 2010 | 12:06 AM
chewyv's Avatar
pm4nudes
got tired of it and converted to manual. shaved a nice 3 pounds
Old Jun 7, 2010 | 12:43 PM
pliskin8's Avatar
sorry it took so long for me to update this post, but here's the cause of the poblem the F***ing were worn down
laoboisosilly
Jun 3, 2009 02:14 PM
p0tential
Jun 21, 2007 04:40 AM
MtbikingKing
Jan 19, 2006 08:21 AM
EX-T
Dec 2, 2003 03:53 PM
EX-T
Nov 27, 2003 07:26 AM
