Tensioner Bolt
Old Sep 6, 2002 | 01:36 PM
95GS-R's Avatar
Default Tensioner Bolt
Is the timing belt tensioner bolt reverse threaded? Is there a way to get the cover around it off without remove the crank pulley?
Old Sep 6, 2002 | 02:21 PM
sgT's Avatar
sgT
Default Re: Tensioner Bolt (95GS-R)
no. and no.
Old Sep 6, 2002 | 05:08 PM
Jared's Avatar
the tensioner bolt? i've never had to remove the tensioner bolt to take off the front cover. it actually has an access hole through the front cover? are you maybe talking about the crank bolt?
Old Sep 6, 2002 | 10:15 PM
95GS-R's Avatar
Default Re: Tensioner Bolt (Jared)
It is just really hard to get too. I could get to it easier if I took that lower cover off, but the crank pulley is in the way.
Old Sep 6, 2002 | 11:43 PM
quickspoolin's Avatar
you can get to it just gotta lower the power steering pully and some others stuff.
Old Sep 8, 2002 | 06:13 AM
95GS-R's Avatar
Default Re: Tensioner Bolt (quickspoolin)
What kind of tool are you using to loosen it, a socket wrench/air tool or what?
Old Sep 17, 2002 | 07:29 AM
95GS-R's Avatar
ttt
Old Sep 17, 2002 | 08:56 AM
CHEETAH's Avatar
there is a a lil plastic cap with an 'ear' on it to pull out. There you can access the tensioner bolt which is a 14mm head. Use a 6pt and not a 12pt. You need leverage so a breaker bar with short 14mm 6pt socket and crack it CCW. Only open by a few threads, dont have to screw off. If you have an Integ or EX civic with PS, good luck !!!
Greg
Old Sep 18, 2002 | 08:12 AM
95GS-R's Avatar
Default Re: Tensioner Bolt (CHEETAH)
Greg
Yes, I do. Even with the PS steering undone and pushed to the side the thing is impossible to get to. Do you recommend removing the motor mount, too?
Otherwise getting leverage is tough.
Old Sep 18, 2002 | 08:32 AM
CHEETAH's Avatar
i use a 1/2" 6pt craftsman 14mm socket with 1/2" craftsman breaker bar. You have to remove crusie control box too ... its been a while since I did one of these on a car that had crusie, PS and AC LOL.
If that fails then jack motor up from bottom and take the mount off. You cant take the bracket off, thats too hard.
greg
Old Sep 18, 2002 | 09:27 AM
95GS-R's Avatar
Thanks Greg.
97accordbuildlx
Dec 11, 2020 07:21 AM
MGX
Sep 5, 2011 12:42 PM
HTautodc
Jul 26, 2009 09:46 AM
whatcivic
Jun 27, 2002 06:11 PM
Scooby
Jun 17, 2002 11:40 AM
