bad cold start
Old Feb 14, 2010 | 07:23 PM
ekcoupeh22's Avatar
Default bad cold start
ok so i have a 2000 coupe with a h22 swap with a skunk2 intake manifold type-r throttle body cold air and a full exhaust running on a stock p13 when i start the car after its been sitting a while in the cold and i start it it idles at like 300 rpm's wants to bogg out and it will stall on first start up and then it feels like its misfiring untill its at full temp. anybody have any ideas?????
Old Feb 14, 2010 | 10:03 PM
white_ej6's Avatar
Default Re: bad cold start
maybe thermostat...or it can be ur idle is to low...maybe you have to adjust your idle...
Old Feb 15, 2010 | 06:08 AM
ekcoupeh22's Avatar
bump! thanks!
Old Feb 15, 2010 | 06:42 AM
Jockone's Avatar
Coolant temp sensor will cause this issue because ecu does not know it is cold so won't apply the "choke"
00vsmcoupe
Dec 31, 2009 05:30 PM
JJexpress
May 19, 2009 03:16 PM
teg racer 877
Sep 28, 2006 01:49 PM
seeodywhy
Sep 1, 2006 05:22 PM
red_sir
Mar 2, 2004 06:15 PM
