Why is my car dying out?!?!
Old Feb 13, 2010 | 08:54 PM
FRKWOO's Avatar
Default Why is my car dying out?!?!
95 eg hatch. on the way home, my radio stopped playing and died out. soon after my dash lights got super dim then windsheild wipers started lagging, like it was low on power. Soon headlight hid's started flickering. then car died out. turned it off and tried starting it but the car clicked like the battery was weak. Then had a friend jump it, drove for about 4 minutes then same thing happened. i think its because of a bad alternator but not sure. wanted input and opinion. Thanks
Old Feb 13, 2010 | 08:55 PM
ReVeNgEd-SoN's Avatar
Default Re: Why is my car dying out?!?!
Bad alternator.
Old Feb 13, 2010 | 09:28 PM
FRKWOO's Avatar
thats what i thought.....anyone else?
Old Feb 13, 2010 | 09:37 PM
Jonathannx2's Avatar
Check to make sure your battery terminals are secure.
Old Feb 13, 2010 | 09:38 PM
Eli2's Avatar
Second the bad alternator. Dont drive it like that unless its to get the alternator replaced otherwise you'll be buying a new battery as well.
The battery is used for starting the vehicle and running acc when the engine is off, when the engine is running the alternator provides the power and charges the battery. So when the alternator goes bad your running the engine and acc completely off the battery which is why everything started to dim as the battery lost its charge
Old Feb 13, 2010 | 09:41 PM
Eli2's Avatar
Seen that happen before too basically the alternator cant charge the battery but that will usually cause a no start condition but when jumped off it runs fine till you cut it off and then it wont start again.
Old Feb 13, 2010 | 10:05 PM
FRKWOO's Avatar
i just checked on my car again, it started on the first crank but it was a struggle.
Old Feb 13, 2010 | 10:09 PM
or sometimes it becomes from shifts.
Old Feb 13, 2010 | 10:38 PM
FRKWOO's Avatar
is there anyway i can test to make sure its the alternator?
Any recommendations on where to get a new alternator?
Old Feb 14, 2010 | 04:30 AM
datboimyEK's Avatar
check the terminal on the alternator to make sure its bolt on all the way....mine did the same thing...and you can always take it to shucks they check it for free
Old Feb 14, 2010 | 08:47 AM
Eli2's Avatar
Did it stay running? Just means the battery is low on charge since it started.
Not sure where u are but autozone and napa checks them for free.
Old Feb 14, 2010 | 08:51 AM
EJ8_Man's Avatar
+1 Alternator is bad
Old Feb 14, 2010 | 09:00 AM
noremorseracing's Avatar
autozone will check it for you and possibly since it is bad they will give u the core for it which means it will be like 10 bux cheaper then if u didnt give them one
Old Feb 14, 2010 | 09:39 AM
ken9's Avatar
Take to auto zone or any mechanic shop that can test your alternator and battery. You can get a new alternator at the dealer or mechanic shop. I think auto zone sell alternator..
Old Feb 14, 2010 | 09:54 AM
dealer or mechanic is way to much $$
mytest23
24
May 6, 2015 07:29 AM
ALLDAY-24
18
May 3, 2011 08:25 AM
ErikDaGenErik
Mar 19, 2007 02:03 PM
iperez
Dec 21, 2006 03:10 AM
eg6madness
Oct 28, 2006 01:37 PM
