skunk2 tuner 2 cams on stock gsr
Old Feb 10, 2010 | 06:02 PM
ALLMOT0REJ1's Avatar
Default skunk2 tuner 2 cams on stock gsr
I've got a good deal on tuner 2 cams with cam gears. I was wondering if I can run these on my stock gsr with stock springs and retainers and valves only has skunk 2 I'm with 68mm tb ima tune it with a s200 hondata? Would it be safe
Old Feb 10, 2010 | 06:13 PM
vtec8200's Avatar
Default Re: skunk2 tuner 2 cams on stock gsr
You cannot run this setup on stock valve train, not even with ITR valvetrain. And you will need a retune. Adjustable cam gears would help a lot . But trust me, its worth it.
Old Feb 10, 2010 | 06:31 PM
So ima need springs and retainers to run thesee
Old Feb 10, 2010 | 06:45 PM
b16a95eg's Avatar
yes you will need springs
Old Feb 10, 2010 | 07:01 PM
vtec8200's Avatar
no choice, unless you dont want to rev past idle
Old Feb 11, 2010 | 06:03 PM
American.Graffiti's Avatar
I wouldnt feel safe doing it. Get the springs and retainers to keep your peace of mind.
Old Feb 14, 2010 | 07:47 AM
chan's Avatar
valve trane needed no other way.
Old Feb 14, 2010 | 08:06 AM
GagnarTheUnruly's Avatar
It won't idle. In fact, you probably couldn't even hand crank it because the stock springs will bind. OP needs springs for those cams.
Old Feb 14, 2010 | 01:29 PM
00Red_SiR's Avatar
All Motor Mentor
While you're correct that he has to change out his springs to run those cams, he could start the engine and idle on them because he'd only be running on the primary lobes which are nearly stock like in their profile. The second he tried to hit VTEC is another story.
Old Feb 14, 2010 | 01:34 PM
Thomascivicsi's Avatar
X2
Old Feb 14, 2010 | 03:14 PM
all-mtr-teg's Avatar
Goes to show what you know about cams and valvetrain. Like mentioned above, the car will idle as it will be running off the primary lobes. I know first hand cause my neighbor was stupid enough to run Pro1 on stock VT and drove the car to the shop to have pro springs installed.
Old Feb 14, 2010 | 03:53 PM
Ooops, yeah I brain farted on that one. Now I feel stupid.
@ all-mtr-teg: Be more like 00Red_SiR, who corrected my error without being a jerk. You have no idea what I know or don't know about valvetrains.
Old Feb 15, 2010 | 02:50 PM
Whiteh2's Avatar
New User
Would the stock bottom end hold to those cams?
Old Feb 15, 2010 | 03:04 PM
Fresh'86's Avatar
^yes, however you would benefit more with a higher compression piston.
Old Feb 15, 2010 | 03:40 PM
93egSLEEPER's Avatar
those cams would love 11.5:1-12:1 CR.
Old Feb 15, 2010 | 07:37 PM
Whiteh2's Avatar
New User
what about those cams+ valvetrain on jdm gsr with ITR pistons?
nice set up?
SORRY TO JACK THREAD MAN
Old Feb 16, 2010 | 06:29 AM
^^^ good setup. P30's would work nicely too.
Old Feb 19, 2010 | 06:52 AM
BearsEK-KMSU's Avatar
Blue Line-GSR baseline Skunk2 IM, 68 TB, DC US GSR 4-1 header Greddy exhaust stock ECU
Red Line- Same as above PLUS S2 Stage 2's and tuned with S200.
Neckbeard
Oct 10, 2018 10:25 PM
bsmith100
51
Nov 30, 2010 09:53 PM
Euro98ITR
Sep 15, 2008 02:47 PM
jonathan13
Jul 6, 2006 01:45 AM
CRXSleeper
Sep 9, 2002 10:47 PM
