crankshaft pully tool?
Old Sep 5, 2002 | 05:54 PM
ndogg's Avatar
Default crankshaft pully tool?
is there i trick i can use to get around this or do i need to go get one? i'm trying to change the timing belt before i drop this motor in my car. (this is my first swap)
Old Sep 5, 2002 | 09:37 PM
Flamenco-T's Avatar
Default Re: crankshaft pully tool? (TYPE EG6)
get either a crank pulley holder about 60 bucks or ring gear holder about 30 bucks...
don;t risk it
Old Sep 5, 2002 | 09:53 PM
salbaje's Avatar
Default Re: crankshaft pully tool? (ndogg)
there are a couple of them out there. you can get one which is the chain looking one for less than 20 bucks. if you were local i could let you use mine.
Old Sep 5, 2002 | 11:27 PM
ndogg's Avatar
Default Re: crankshaft pully tool? (salbaje)
ya, i was talking to my buddy and he has a "chain wrench" that he used to do his. i have an impact gun but it is too weak. do you think i will be able to get it with an 18" breaker or will i need a bigger one? (i'm a pretty big ****)
what do you mean "don't risk it"? also, is the ring gear holder the same thing as the chain wrench thing we are talking about?
[Modified by ndogg, 12:29 AM 9/6/2002]
Old Sep 5, 2002 | 11:52 PM
riceboy's Avatar
its a specialty tool, you can get one at a local Honda dealer (or at least at my local Honda dealership you can, dunno about yours)
Old Sep 6, 2002 | 08:00 AM
earl's Avatar
Default Re: crankshaft pully tool? (riceboy)
Don't use the chain tool as it messes up your crank pulley. Big impact or buy the holder.
Old Sep 6, 2002 | 10:11 AM
erniecars's Avatar
Default Re: crankshaft pully tool? (earl)
take the oil pan off and block the crank then use a breaker bar. Its very easy.
Old Sep 6, 2002 | 10:18 AM
yaya's Avatar
Default Re: crankshaft pully tool? (erniecars)
shove a crowbar into the flywheel+breaker bar=?
Old Sep 6, 2002 | 10:21 AM
94CivicSi's Avatar
I've got the same problem. Litterally, slide a block of wood inbetween the crank and the block? Will a piece of 2" x 4" in fit in there?
I was lookind around for the 1 7/8" hex too also but I doubt I have the stength to hold the pulley AND break the bolt loose.
Old Sep 6, 2002 | 11:04 AM
Redline130's Avatar
Here's one for about $40: http://www.thetoolwarehouse.net/shop/SP-60100.html
I have one, and it has come in very handy. It's good for not only removing the crank pulley, but stopping the crank from spinning while taking off the flywheel bolts as well.
[Modified by cyber13, 12:07 PM 9/6/2002]
Old Sep 6, 2002 | 11:17 AM
ElectronMan's Avatar
Default Re: crankshaft pully tool? (cyber13)
Or... If the car is close enough to the ground. You can put the socket and breaker bar on the pully bolt, let the breaker bar rest against the ground pointing to the rear of the vehicle, and bump the starter. should loosen it right up.
Old Sep 6, 2002 | 11:47 AM
JHill's Avatar
Default Re: crankshaft pully tool? (ElectronMan)
No, the engine turns the wrong way to do this, it would simply destroy something if you do this with a B or H series engine which turns counter-clockwise.
Old Sep 6, 2002 | 05:17 PM
Jared's Avatar
Default Re: crankshaft pully tool? (JHill)
I have one of these:
http://www.matcotools.com/Catalog/to...&page=1&#37533
basically the same thing, but backed by matco so when i break it, the tool guy will just swap with me.
Old Sep 6, 2002 | 06:18 PM
XKWISIT1's Avatar
If you don't have the tool, do what i do. This will only work if there is some other part on the engine with a pulley. First grab one of the old belts, the larger the better. Then put it around the crank pulley, next wrap the belt around another pulley, like the a/c tensioner pulley or the p/s pulley. Now because the belt is too large on the pulley, this lets you wrap the belt on it's self. As you turn the crank to loosen the bolt tuck the lower part of the belt under the upper part of the belt, this will cause the belt to tighen on it's self, preventing the crank from turning. The harder you turn it ,the tighter the belt grabs, acting like a brake on the crank. This allows you to loosen the bolt
modernvisionscc
Aug 4, 2007 05:15 PM
downeyballz
May 15, 2007 03:16 PM
wickedplastikman
Nov 8, 2004 10:49 PM
gulf imports
Aug 16, 2003 02:26 PM
