what kind of ets and traps
Old Feb 3, 2010 | 05:20 PM
lsvtechatch92's Avatar
Default what kind of ets and traps
what kind of ets and traps should one expect in a eg chassis making from 420 to 450 whp?
Old Feb 3, 2010 | 05:34 PM
quis84's Avatar
Default Re: what kind of ets and traps
from what i have seen with the right track and right driver you could go high ten's. Or be stuck in the 11.2-11.0 range for ever. Its a lot variables that come in to effect. For the trap speed i would guess high 120's, also the weight of the car is going to play a factor obviously the lighter the eg the faster it will be with less power.
Old Feb 3, 2010 | 05:39 PM
Any other opinions
Old Feb 3, 2010 | 05:43 PM
hatch34's Avatar
i went 10.7@133 with a 1.9 60ft in a 2600lb hatch making about 460
Old Feb 3, 2010 | 06:25 PM
any one else
Old Feb 3, 2010 | 06:29 PM
sanman000719's Avatar
11.0@134 for me at 460
Old Feb 3, 2010 | 06:36 PM
Poootie's Avatar
i was going 11.0@124-127mph on 15psi with 1.6 sixty foots(about 410whp'ish)
It was a EK tho (2356lbs with me in it)
But i say , there is only one way to find out. Go out and race!!
Old Feb 3, 2010 | 06:40 PM
i dream of 1.6's lol i was around 1.79 lol
Old Feb 3, 2010 | 06:46 PM
Poootie's Avatar
less is more..
The more boost i was putting in the short track the worse my 60 foots became. (some of my best 60 foots were with 14psi in 1st and 15psi in all other gears.. best was a 1.60)
This was a pass with a lil more power (17psi in 1st and 20 psi in 2nd-4th)..
I let off and coasted after the 1000'
still went 11.9@85mph. But holy $hitty sixty.
Old Feb 3, 2010 | 09:25 PM
come on guys post up some of your times with those power levels or what you have seen
Old Feb 4, 2010 | 07:03 AM
unusual71's Avatar
its gonna depend largely on gearing and chassis setup not just power. 400whp is more than you can hook in first and even maybe in second so the amount of power you can actually put the ground without smoking the bolognas is gonna dictate how fast you run.
give us more info on the chassis, however at that power level 10's are possible with 13X mph traps
Old Feb 4, 2010 | 07:40 AM
Poootie's Avatar
Really tho, you are in Tx. I know the track is open.. GO RACING.
Report back with results.
Old Feb 4, 2010 | 08:18 AM
going to track on friday if weather permits! car is a eg coupe i have full supsension and traction bars....
Old Feb 5, 2010 | 02:06 PM
wish me luck headed to the track!!!!
Str Pro
Jun 20, 2019 06:54 PM
DC2_R
Dec 11, 2009 02:56 PM
legends
Jan 5, 2005 04:06 PM
hatchboy93
17
Nov 10, 2003 10:24 PM
Mugen_R
21
Nov 15, 2001 07:55 AM
