my b20 idles real high
ok my b20 vtec turbo idles at bout 3000 rpm when it warms up it idles at 2400 does anyone know what it could the car was sitting for bout 1 month before it started this problem no check engine light either
no vaccum leaks what happened was i shipped my car to hawaii before i did that it was running fine then i got it in hawaii a month later its idle high but there are no vaccum leaks i so stumped on it
well then check to see if your throttle cable is stuck, try adjusting your tb screw, look for any coolant leaking, and if you havent then re bleed your coolant system
you start your car without the radiator? kinda crazy, is this a half size or full size radiator. maybe dramatic temperature differences can be the problem?
skerrttt
Apr 26, 2013 07:19 PM
