crank no start
Old Jan 31, 2010 | 03:26 PM
sohcrx91331's Avatar
Default crank no start
ok so i have a 91 crx dx with the 1.5L DPFI.the car cranks over but it wont start.it sounds like it wants to but nothing.i have spark and fuel but the engine is flooding i think.after cranking it for a while the engine backfires thru the throttle body.i have no idea where to start.Any help will be greatly appreciated,thank you in advance
Old Jan 31, 2010 | 03:44 PM
vtec_ef8's Avatar
Default Re: crank no start
make sure the rotor in the dizzy didnt fall off.
Old Jan 31, 2010 | 07:36 PM
checked it and it was okay.i was thinking maybe injectors are bad and leaking fuel cuz i cleaned my throttle body
Old Jan 31, 2010 | 09:20 PM
rex89si's Avatar
Mine would do the same thing after sitting for awhile. Try putting in new spark plugs and turning the engine over 1 revolution at a time with the key and turn key off and repeat and hopefully it will crank. I hope this helps, it did for me.
Old Feb 2, 2010 | 11:58 AM
i figured out what the problem was.si i was leaking oil from my dizzy o-ring and i put a new one in.when i did this i guess the tooth that grabs onto the cam moved 180 degress.i was on #4 spark plug when i should've been at #1.turned the dizzy back,put everything together and it started right up.thanks for the help anyways everyone!
skwigelf
May 26, 2014 05:57 PM
Serge L
Feb 25, 2012 04:45 PM
hollowman8904
Jan 7, 2009 08:59 PM
idrivecrx
Jan 24, 2006 06:05 PM
MrPotatoeHead
Nov 6, 2005 06:45 PM
