integra surging ..possible iac valve problem
Old Jan 29, 2010 | 09:32 AM
2ndchirp's Avatar
Default integra surging ..possible iac valve problem
i put my intake manifold on a different engine and the car surges up and down from 1 to 2k...the i iac valva was just fine in my other motor what can cause this ?
Old Jan 30, 2010 | 06:39 PM
DeucesGoneWild's Avatar
Default Re: integra surging ..possible iac valve problem
my car was doing that. turned out to be the tps. good luck.
Old Jan 30, 2010 | 06:42 PM
scbmx87's Avatar
If you swapped the intake manifolds it's probably a vaccum leak.
Old Feb 1, 2010 | 07:18 PM
2ndchirp's Avatar
i used a new gasket... after bleeding the system it does it once in a while now..then it stops
Old Feb 1, 2010 | 07:45 PM
ARdb8's Avatar
yea.. 1. vacuum leak 2. low coolant 3. sensor malf? tps, map, iacv...
93SiPrelude
Feb 24, 2008 10:39 PM
91Civic300K
Dec 20, 2007 09:18 PM
ilu
Apr 19, 2006 03:08 PM
GaRn
May 20, 2004 09:29 AM
Projectg2i
Jan 12, 2003 01:21 PM
