IACV Fried my ECU
Old Jan 28, 2010 | 10:23 AM
EdSales's Avatar
Default IACV Fried my ECU
1st off, let me give a short brief on my car. I swapped in a B16A into a 92 Civic CX shell I bought about 8 months ago. Ever since I've had the thing running, I've had Cell #14, IACV. I have cleaned it, tested it by running power and ground directly to it, and watched it work like its supposed to, but still I get the CEL and still at around 1600 RPM's the Idle would bounce around and cause the car to bounce until I got the RPMs above.
Anyways, I took my ECU to Inline Pro to get them to chip it with Hondata S300J, in preparation for my Turbo. They take the ECU apart to inspect it, and I hear him say, "Oh, Toasty." He showed me where it was fried, and asked if the ECU worked. It did, I had just pulled it out days before, and he asks if I've had IACV problems.
So I told him my story, and he thinks the IACV Wire 'Green/White' and the AIT 'Red/Yellow' Wires got crossed up in the ECU. I go back home, with the map of the ECU Wires they had provided me, and everything was lined up the way it should.
So, could a bad IACV Sensor have caused the positive current back to the ECU? Could I have plugged the IACV Sensor in the wrong place when I first installed the swap that caused the surge, and if so, since the resistor blew, will replacing the resistor fix my IACV?
Any ideas or adivce would be appreciated. Plan on getting the ECU fixed, but don't want to re-install the ECU after getting the resistor replaced and popping it again.
BTW, the ECU still runs fine without that 1 resistor, just got the 1600 RPM Problem as listed above.
Thanks again.
Old Jan 28, 2010 | 12:42 PM
92ehatch's Avatar
Default Re: IACV Fried my ECU
could have installed the IACV wire on an incorrect sensor and fried it.
i doubt the IACV could have fried it otherwise
Old Jan 28, 2010 | 01:42 PM
94EG8's Avatar
Seagull Management
Wire colors for IACV should be blue/yellow and yellow/black. Wire colors for the IAT should be red/yellow and green/white. Wire colors for the Evap purge solenoid are red and yellow/black. All three use identical plugs and are in close proximity to each other, its easily possible that 2 of them are plugged into the wrong sensors. I can tell you plugging the IACV connector into the IAT sensor will pretty much instantanously kill the IAT sensor (ask me how I know).
Old Jan 28, 2010 | 01:58 PM
eli92188's Avatar
???? how can u plug the wrong clip into the wrong connecter...i dont think it would let u udd break it bfor u do that..lol
Old Jan 28, 2010 | 02:21 PM
94EG8's Avatar
Seagull Management
All 3 connectors use identical plugs. All are close enough that you can plug them into the wrong sensor.
Old Jan 28, 2010 | 10:03 PM
EdSales's Avatar
Man I owe you some major props! I had the Evap Purge Solenoid Connector (Red and Yellow/Black) Plugged into the IACV! I haven't gone out and looked at it yet, but when I was pulling ECU Pin Outs, I know I had Red and Yellow/Black plugged into IACV. Where would the IAT Connector and where the Evap Purge Connector be in relation to the IACV?
Thanks again for that!
Old Jan 28, 2010 | 10:17 PM
b18cKoupe's Avatar
is it really you eli??
Old Jan 29, 2010 | 05:12 AM
EdSales's Avatar
Still haven't been able to find where the Evap Sesnor Connector is supposed to go. The IAT sensor was in the right spot. Just got to find where the Evap Sensor is supposed to go because thats where my IACV Connector is at now so I can switch them.
Old Jan 29, 2010 | 06:24 AM
rick_rabies's Avatar
I'm not Rick!
man that guy has a big neck.
Old Jan 29, 2010 | 07:47 AM
EdSales's Avatar
I do not appear to have a IACV Connector, it must have been lopped off during the swap. And the JDM Engine doesn't have an Evap Purge Solenoid. Could I run the Green/White Wire which is the IACV Wire from the ECU to a 2 Pin Connector and splice a Yellow/Black Wire into it to provide it with the Ground/Positive, which ever one it is?
Old Jan 29, 2010 | 07:48 AM
I'm not Rick!
sounds like you need to search for a wiring schematic for that car. GL
Old Jan 30, 2010 | 01:10 AM
eli92188's Avatar
yea whos this???
roosie
Engine Management and Tuning
Jun 12, 2019 09:46 PM
§95HATCH§
May 16, 2009 07:19 PM
b16ahybrid
Feb 13, 2006 02:44 PM
Adam.C
Mar 29, 2004 02:22 PM
aw1234dude
Oct 8, 2003 08:03 PM
