Revving? ECU maybe?
I have a 90 hatch si. has a d15b7 in it and it revs almost constantly.
I've cleaned out the iacv but i noticed that my ecu says it came from a 91 integra. is that ok? or is there one i should go with
adjusting the throttle isn't going to change squat.
does this engine have a fitv on the underside of the throttle body? if so, it can cause erradic idle. with the engine running unplug the iacv and see if the idle drops down to normal. if it does, then you need to replace it. if it doesn't, then your problem lies elsewhere.
b7 doesnt have a fitv. youve either got a bad iacv broken or stuck pcv valve or other large vaccum leak. i will say that cleanin an iacv doesnt always work. its a stepper motor that can and does go bad. try replacing it with a known good one before you say its working. or take of intake tube and plug the hole in throttlebody that leads to iacv if car stalls or comes down to normal its prob bad.
the b7 does have a fitv stock. maybe yours doesn't, but it should be there.
when he said revs almost constantly i interpreted that as constantly revving up and down, not revving at a constant. it was poorly worded and we'll have to wait for the op to clarify.
I don't know how this works but maybe somebody can help me I just got a 95 civic hatchback with a b18c1 motor in it and at start up it revs up and down fast for about ten mins until it warms up and after it still does it a little bit I don't know anything about motors so I came here maybe u can help me or know somebody that can...
P.S. Somebody told me it mite be the iec controler or something like that..
Thanks
Cody...
Thanks
Cody...
Don't thread jack, its rude. message a moderator if you don't know how to search or start your own thread.
"Constant high idle" to be specific? You could also try bleeding your radiator. air bubbles can get stuck in tubes and throw things off. just an idea.
