ls vs. sohc vtec
Old Sep 5, 2002 | 09:41 AM
b16coupe93's Avatar
Default ls vs. sohc vtec
i am stuck between going with an ls motor with some internal work or going with a sohc vtec turbo and some work in my 93 coupe what should i do (pros and cons on both )
Old Sep 5, 2002 | 09:47 AM
vtecvoodoo's Avatar
Future Texas Boy
Community Builder
Default Re: ls vs. sohc vtec (JDM93Eg)
depends on your budget and what you want to do w/ your rizzzzzide.
Old Sep 5, 2002 | 10:35 AM
fire7882's Avatar
ls unless you are one of those sohc pride guys. the ls has more potintial(sp).
Old Sep 5, 2002 | 10:36 AM
JSJ EG6's Avatar
Default Re: ls vs. sohc vtec (fire7882)
go ls. i think sohc ant even worth it unless you got hella money.
VTC_CiViC's Avatar
LS Turbo or LS NA? If you're thinking about staying NA on the LS, stick with the D16 and turbo it, otherwise, the LS will yield ALOT more power than the D16 will on boost.
Old Sep 5, 2002 | 12:21 PM
HarryB's Avatar
From: Where All Funky Things Come From...., Stankonia, USA
Default Re: ls vs. sohc vtec (VTC_slow_CiViC)
I am actually in the same situation. I dont know where to get a b18b and keep it NA for now or just stay with my d16z6 turbo until I can get a b18c R swap.
I think im going to stay turbo.
Old Sep 5, 2002 | 12:26 PM
lsvtec101's Avatar
Default ls.
ls baby! im doing my turbo kit on my ls under 1600!! that will smoke any turboed sohc.. my brother is doing a d16y7 bottom end with his y8 head and 7psi with a fmu and spearco intercooler.. i think ill smoke him with my 10 haha
Old Sep 5, 2002 | 05:43 PM
b16coupe93's Avatar
Default Re: ls vs. sohc vtec (civic@uofw)
what is you sohc turbo run in the 1/4 ,if you have run it and if not is it a big difference in power and speed
Old Sep 5, 2002 | 10:58 PM
Halive's Avatar
New User
from what little info I have found(I was considering and still am about doing this swap) a ls n/a seems pretty quick in a eg. Some say they have ran 14.5 with i/h/e and a b16 tranny...thats not too bad...
Old Sep 6, 2002 | 02:57 AM
Bleed Black's Avatar
Default Re: ls vs. sohc vtec (Halive)
all depends on what you want to do in the future . ie Potential
Old Sep 6, 2002 | 04:16 AM
F.U.'s Avatar
Default Re: ls vs. sohc vtec (slowasshatch)
i have the soch crap. GO DOHC>.trust me you wont regret anything, I used to be a SOHC man but now i realize the DOHC have alot more potential. Go DOHC
Old Sep 6, 2002 | 06:43 AM
b16coupe93's Avatar
Default Re: ls vs. sohc vtec (SpoonHatchBack)
i want a car that i can drive daily but still have the power to race cars that i wouldnt beat now , i mean i hang door to door with gsr's a a sohc vtec i/h/e/ now and i want to really smoke these kinds of cars .....if i do the ls i plan to have i/h/e ,cams , cam gears , pistons , rods all that good ****
thanks for the help i think i am going ls
Old Sep 6, 2002 | 07:25 AM
yaya's Avatar
you will be disapointed with an ls, even with 1000 bucks into it, it will suck dude
turbo the sohc! or get a b18C
[Modified by BrianP, 4:45 PM 9/6/2002]
Old Sep 6, 2002 | 08:35 AM
Default Re: ls vs. sohc vtec (BrianP)
You can also look at it this way. Virtually every B-series part is more expensive and harder to find than any D-series part. So if you blow your SOHC its like a $300 repair where-as if you blow the B its a going to be at least double that.
Old Sep 6, 2002 | 10:32 AM
94civicx's Avatar
New User
Used to have a sohc and now have the ls motor. Hands down no comparison the ls is by far better anyway you look at it. The ls has more torque and mixed with turbo is a street beast. keep in mind that the ls is better to boost also because of the compression which allows you to run higher boost on stock internals
Old Sep 6, 2002 | 11:43 AM
89JDMcrx's Avatar
Default Re: ls vs. sohc vtec (94civicx)
yeah, but you can always get low compression pistons can't you?
Old Sep 7, 2002 | 11:18 AM
vteckid33's Avatar
Default Re: ls vs. sohc vtec (97exracer)
Go with the ls and then later save up your money get a vtec head and go ls/vtec
Old Sep 7, 2002 | 11:48 AM
mantic6t9's Avatar
Why does eveyone think lower compression will make more power because you can run higher boost? Think about it.... You're just making up for the loss of compression.And the lower compression you gothe more psi you have to dump into the motor to make up for it. Hmm so? what does that matter? Well it makes everything less efficiant,that means you are loosing power.Many people do not realize this, thats why they bitch when someone wants to boost a typeR engine.If you think i'm full of **** thats fine prove me wrong.
Old Sep 7, 2002 | 12:45 PM
W.Zero's Avatar
go LS and down the line you can change it to vtec
Old Sep 7, 2002 | 01:19 PM
JV's Avatar
JV
Who?
If you are going to keep the B18B NA, don't even bother. A boosted single cam VTEC will eat the "worked" LS alive...
So many people are boosting their D16's and putting out extremely respectable #'s on stock internals. You will never get this with an NA LS motor...
[Modified by JV, 5:20 PM 9/7/2002]
Old Sep 7, 2002 | 02:52 PM
CRXSleeper's Avatar
Default Re: ls vs. sohc vtec (JV)
How come no one mentions a head package set up for the SOHC. They go for about $1300-1500. And they will give you huge gains and aren't too expensive. Am i missing something here cause that sounds like a good idea to me.
Old Sep 7, 2002 | 03:59 PM
turboman's Avatar
Default Re: ls vs. sohc vtec (CRXSleeper)
I stuck with my SOHC. I spent around $7000 all together between having a motor built, hondata, and turbo. I can get up to 300hp or more(lets not try 220 is enough).
I didn't build it myself. So you can do it for alot less if you did it. I can work late at the office and easlily pay for the extra cost so why not let a shop do it I say. Plus if anything goes wrong I got someone else to blame it on
But hey you got to do what you want. LS would probably have more torque for daily use. The SOHC you have to gun it all the time to get it going. Which I do find to be a pain if I have to drive in traffic.
Old Sep 7, 2002 | 04:11 PM
shermanyang's Avatar
Default Re: ls vs. sohc vtec (mantic6t9)
with lower compression you have a wider tuning ability and you're less prone to detinate. sure you'll make less power than a B16 or a B18c but you'll be safer in the long run when you do wanna turn up the boost. and another thing, you can't lose power that you don't have. pushing a certain amount of psi into a cylinder doesn't mean you're gonna get so much power. it just means that your turbo might just have to work hard to make the same amount of power.
so all in all, an ls is better to turbo if you're not gonna go all out and want to stay under 10lbs of boost with stock internals.
[Modified by shermanyang, 1:14 AM 9/8/2002]
BRG+Honda=JDM
May 6, 2007 12:29 PM
Felixthecatz6
38
Feb 1, 2007 03:06 AM
Slowass2dr
17
Aug 20, 2006 11:23 AM
jdmstreethatch
Jan 28, 2004 08:57 PM
Eg6_RcR
Jan 28, 2004 08:32 PM
