Fuel management on a D16
Old Sep 5, 2002 | 08:40 AM
BorderM3's Avatar
Default Fuel management on a D16
Do you guys think i could get away with stock fuel pump and stock injectors running stock boost on a MHI-TD05H-14b (1st gen mitsu turbo) its like 8lbs stock i believe. If i run a S-AFC.
I have a FMU and dsm 450cc injectors, but i need resistor pack and fuel pump.
Thanks
Old Sep 5, 2002 | 11:44 AM
CzanSOHC's Avatar
Default Re: Fuel management on a D16 (BorderM3)
nope, just get teh resitor box or make your own...not that hard...do be cheap....will cost you more in the long run.
Old Sep 5, 2002 | 11:58 AM
autoEXturbo's Avatar
at 8psi your definitely gonna strain your injectors and pump. Hell i knew a guy running 5psi and seized his pump then his motor blew. What i did was get the rc 440's, vortech fmu, something for the map sensor, 255lph fuel pump and a vafc and then pushed it to 8psi. Inlinepro recommended it to me, I did it and the car worked fine.
thanh4o8
Feb 6, 2009 10:53 AM
xxscaxx
Mar 8, 2005 02:16 PM
rjardy
Oct 14, 2002 08:15 AM
DJ0820
Aug 1, 2002 11:56 AM
