what size is the shaft on a gt30r turbo?
the wheel got damage due to sucking in the mesh cover. so im trying to see what is out there for a compressor wheel replacement. turbo still work fine with slight chips on the tips wheel and maybe slight bends.
What part of CA you in? I know a guy that can help you, i had a similar issue with a 40R and he was able to replace the wheel and rebalanced the turbo on a VSR, PM me if you want more info, good luck.
Yep.. The actual GT3076R wheel only comes with the cartridge but there are replacements that are similar. They are only the same size, though and not larger.
do you know who sells replacement wheel for the turbo? or can mod. the backing plate for a bigger wheel?
b20sedan
Mar 1, 2018 11:11 AM
Jianshatch
Jun 13, 2017 09:08 AM
