What shift linkage can i use for hydro clutch for my Ef?
Old Jan 25, 2010 | 09:16 PM
Efjdm88's Avatar
Post What shift linkage can i use for hydro clutch for my Ef?
I have a 88 Honda civic sedan and i im going to swap a turbo'd d16y8 into it and I've been asking around and i cant seem to get a answer i don't really want to spend a lot of cash on a hasport shift linkage.... i already have the hasport cable to hydro adapter... so i was wondering if there is a alternative shiftl linkage i can use any help will be greatly appreciated!!
Old Jan 25, 2010 | 10:29 PM
pearl95sc's Avatar
Default Re: What shift linkage can i use for hydro clutch for my Ef?
Use the stock linkage from the cable trans, you'll need to drill out the holes on the base of the stabilizer arm to slide it over to the right (pass side) where it mounts to the trans. If you don't the shifter bars will rub, and you'll be questioning what gear you're in. You don't need to move it over much, maybe 3/8 inch. My bars touch ever so slightly when going for 1st or 2nd gear, but you'll never notice when driving. If a photo helps, I'll try to snap one next time car is on the stands.
Old Jan 26, 2010 | 05:15 AM
Sikocivic's Avatar
Why not just keep the cable tranny? It bolts up to the D16y8 motor. It would save you the hassle of doing the hydro swap.
Old Jan 26, 2010 | 06:08 AM
SIred91's Avatar
Rainman
gear ratio on the cable trans is better adn they are a LOT cheaper to replace and find in junkyards in awesome shape.
Old Jan 26, 2010 | 07:31 AM
Efjdm88's Avatar
well i was thinking of keeping my cable tranny but i didnt think the tranny would hold the amount of boost im going to be running in my d16y8. the motor is getting rebulit and the guy at the shop told me he estamates that i well be running 465hp so i was concerned mainly on that but if i can use my cable tranny i will but let me know what you guys think
Old Jan 26, 2010 | 09:09 AM
Staypuff578's Avatar
465hp? are you gonnna boost like 200 pounds?
Old Jan 26, 2010 | 09:12 AM
hatchet_honda's Avatar
lol when i seen that number!! 465hp!?? yeaaaa i dont think so. your cable trans will work juuuuust fine.
Old Jan 26, 2010 | 09:30 AM
Deetz's Avatar
Crazy Honda Guy
I'm not going to say you can't make 465hp, but with that kind of power you will have had to spent some very serious cash for such a setup!!!!
The engine would have to be built from the bottom up....sleeved, forged rods and pistons. You would need both a big time fuel up grade as well as cooling system, plus a good engine management system.......have you done all this????
Old Jan 26, 2010 | 03:07 PM
Efjdm88's Avatar
yes i have i spent a lot of time buying all the parts i need to make that much horsepower out of my d16y8, i started this project when i was 15 years old and i am now 22. as you can tell ive been saving alot of cash to do this much work... i know people will tell my why dont i go with a b-series or k-series but i dont want to be like everyone else. so i decided then (when i was 15) i would for sure get a d16y8 to push out 465hp.... and ive seen alot of single on you tube pushing out more horse power then 465hp so i know it can be done....
Old Jan 26, 2010 | 03:11 PM
good luck on your build
Efjdm88's Avatar
when i get some pictures of the car and engine i will post them up
Old Jan 26, 2010 | 03:19 PM
Efjdm88's Avatar
thanks for the motivation... the guy at the shop told me it should be done in a week
Old Jan 26, 2010 | 03:23 PM
Sikocivic's Avatar
Sounds like a nice setup. Can you give us a rundown on what turbo, manifold and engine management system you are using? Pics would be great too.
rstchris
Transmission & Drivetrain
Jan 29, 2012 04:09 PM
spikey0123
Nov 17, 2011 06:51 PM
EF9_RIDER37
11
Nov 11, 2009 11:34 AM
us31wking
Jul 11, 2007 02:40 PM
m3guy87
Nov 21, 2001 10:03 AM
