swapped heads now fuel in every cylinder and wont idle
Old Jan 25, 2010 | 05:07 PM
fourdoorteg's Avatar
Default swapped heads now fuel in every cylinder and wont idle
i just put a another head on my b18 and i used everything else from my old motor(ran fine but needed a new hg). Now the car doesnt want to run. it will crank but barely and sporatically idle. Im 95 percent sure the timing is correct.
I pulled the spark plugs and saw fuel on all the pistons and like gas vapor rising from the cylinders. Im about to check the distributor but i just replaced the cap and ignitor and plugs and wires are good. please help
Old Jan 25, 2010 | 05:09 PM
91tegrals's Avatar
Default Re: swapped heads now fuel in every cylinder and wont idle
are all your vacumme lines correct
Jmcalderon4617
May 28, 2018 03:22 PM
delisle
Feb 12, 2018 09:30 AM
gmon
Dec 13, 2012 08:46 PM
brolli
Sep 1, 2005 08:03 AM
jpelle
Mar 15, 2002 12:46 PM
