Color cods, Need help
Old Sep 5, 2002 | 03:48 AM
migo's Avatar
New User
Default Color codes Bearings, Need help LS block
How can I get the color codes off the block. Is there any marking on the crank that can provide that information. When rebuilding a motor, Do you have to used Honda bearings due to the coating...I'm building a B18a and H22a
[Modified by D.SPECS, 12:59 PM 9/5/2002]
Old Sep 5, 2002 | 08:58 AM
migo's Avatar
New User
Default Re: Color cods, Need help (D.SPECS)
Come on, don't tell you guys don't know
Old Sep 5, 2002 | 09:20 AM
sgT's Avatar
sgT
Default Re: Color codes Bearings, Need help LS block (D.SPECS)
take the number on the crank and match to the letter on the block for the bearing color.
if you have a manual you should know this. if you dont have one, get one.
Old Sep 5, 2002 | 10:24 AM
areyouasian's Avatar
you can also take the number to a honda parts counter and they will tell you what you need.
Old Sep 5, 2002 | 07:59 PM
migo's Avatar
New User
Default Re: Color cods, Need help (areyouasian)
anyone experience bearing problem
Old Sep 5, 2002 | 08:31 PM
im experience bearing problems...i went to honda and tried to get bearings for my h22...they all on backorder until 9/13...to top that off all the other parts i needed for my swap is on backorder.... which puts a delay on my swap which was supposed to be done already....daymn HONDA need to get off their lazy butts and make my shiet already!
Old Sep 5, 2002 | 08:47 PM
earl's Avatar
I stock ACL's bearings for all Hondas for immediate delivery. Sorry about the cheap commercial
Old Sep 5, 2002 | 09:43 PM
Flamenco-T's Avatar
Default Re: Color cods, Need help (earl)
you need to take out your block to see which combination you have, YOU CAN NOT GO TO DEALERSHIP AND EXPECT THEM TO GIVE YOU THE RIGHT COLOR CODE. every block has a different combination. To avoid downtime, I suggest get ACL, they're standard size, and they will fit whichever color of bearings you need...
I have ACL and they are all within specs, if I had to wait for the damn dealer backorder list, I'd have still have no car by now ( 60 days BO for brown color)
stan
Old Sep 6, 2002 | 12:45 AM
tonyxcom's Avatar
Default Re: Color cods, Need help (Flamenco-NA)
ive got 3 brown main bearing here now that Carland Acura sent me by mistake.
Spoon84
Dec 31, 2007 01:18 AM
boosted k20
Jan 12, 2005 09:06 PM
gundamgsr
Aug 23, 2004 10:27 PM
b20ek
Jun 2, 2003 11:08 PM
Teg15
Sep 1, 2002 01:12 PM
