air induction ideas?
i still have to fiberglass an L shaped turn on the back to the turbo
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/diy-conversion-eg-headlight-housing-into-turbo-intake-2654480/
both good ideas, but not sure they'll work. Gotta keep both headlights to be legal, and intercooler tubing could be in the way of the fog light opening.
Are corner lights required? Maybe make a duct through there?
so to clarify, your car is boosted correct? best way to get air to the turbo and cool it is to create a custom ducting in the front grill to direct air while your car is moving to the turbo.
93egSLEEPER: Yes, the car will be boosted. The question is just where to pull it in. That's the point of this thread... A custom ducting from where? I know I could take a hole saw to the bumper, but that's not very creative.
And Dan, that's awesome. I'm going to have to think about that one more though.
well the bumper wouldnt work. you have the bumper support (which i doubt you want to ditch yet) and teh intercooler so it has to be from the hood or headlights or a...snorkel lol
I cut a hole i n my bumper, and fit a coupling in it and on the other side slip a flex hose over the coupling, seal it with a worm clamp and run the hose to the filter.
Got the Idea from the local tune shop. you can use a headlight if you don't use the light. A velocity stack would be most ideal.
Vagitarian
May 18, 2013 09:16 AM
lucas569
Oct 29, 2002 10:50 AM
