Integra rear wheel hub bearing
Old Jan 23, 2010 | 12:33 PM
norcalB18's Avatar
Default Integra rear wheel hub bearing
Both of my bearings are going bad in my rear wheels. When i jack up the car both wheels wiggle just a bit. As of right now it doesn't really make any noise but i want to change them soon b4 my wheel falls off or something.
Is it cheaper to just buy a new bearing and have the shop press it or should i just buy the whole hub assembly?
Also where can i find these parts for a lil cheap but with oem quality?
Old Jan 23, 2010 | 12:51 PM
mrdeadman's Avatar
They let me pick
Default Re: Integra rear wheel hub bearing
Bearings are like $40 each. And depending on which shop you have do the press work it could be $20 or it could be $80 each.
Old Jan 23, 2010 | 05:02 PM
norcalB18's Avatar
how much does it cost for a whole new oem hub from the dealers? Any websites have the real deal for lil cheaper?
Old Jan 23, 2010 | 05:19 PM
Dogginator's Avatar
Daisy... Daisy...
For a 94-01 non-ITR, the p/n is 42200-SR3-A53. They are about $150 each.
http://www.hondapartsunlimited.com/i...&submit=submit
I would look into the aftermarket bearings.
Old Jan 24, 2010 | 02:43 PM
norcalB18's Avatar
Who makes the aftermarket hub bearings? Is it really worth it? OEM usually lasts really long without any problems
Old Jan 24, 2010 | 03:24 PM
Dogginator's Avatar
Daisy... Daisy...
There are aftermarket parts.
http://www.google.com/products?q=int...l=en&scoring=p
Old Jan 24, 2010 | 04:46 PM
jtome's Avatar
good info, ill be replacinig both my rear wheel bearing soon, i will just buy the beearing and have it pressed...
Old Jan 24, 2010 | 04:53 PM
josh-roy's Avatar
I have aftermarket hubs. There cheaper and they've lasted 2 years so far and are still going strong.
lowtegsr
Jan 31, 2008 04:30 PM
Hemix
10
Mar 5, 2007 06:12 PM
XkjeldorX
Mar 28, 2006 03:39 PM
g-ride-si
Sep 13, 2005 08:36 AM
BrandonClaps
Jun 20, 2003 11:20 PM
