rear wheel bearing ???
Old Mar 25, 2006 | 07:03 PM
XkjeldorX's Avatar
Default rear wheel bearing ???
i'ved searched and searched and havent found an actual answer.
is it possible to just replace the rear wheel bearing without having to buy the whole hub assembly? i read yes and no so i just want to make sure. would greatly appriciate an answer. thanx
Old Mar 25, 2006 | 08:26 PM
XkjeldorX's Avatar
night bump
Old Mar 26, 2006 | 07:18 PM
XkjeldorX's Avatar
can anyone elaborate. im still searching aswell
Old Mar 27, 2006 | 12:19 PM
B18C1EM1's Avatar
yea u can replace just the bearing
Old Mar 27, 2006 | 04:04 PM
XkjeldorX's Avatar
Default Re: (B18C1EM1)
thanx for answering. would anyone have the part number so i can get the oem bearing? i'ved search and cant seen to find just the bearing p/n.
Old Mar 27, 2006 | 09:03 PM
so lazy's Avatar
Default Re: rear wheel bearing ??? (XkjeldorX)
just go to a LOCAL autoparts store like ADVANCE auto they will have a rear hub assy. for like $50 if your car is a integra that is.. go with that it works fine i did it for my friend... if you get the bearings you will have to go get the old bearings pressed out which will cost you alittle bit more money... so go to ADVANCE... good luck..
Old Mar 28, 2006 | 03:39 PM
XkjeldorX's Avatar
Default Re: rear wheel bearing ??? (dc2-guy)
i have 2000 civic si hubs so i guess that would be a but more. i think the 94 and up integra and 00 civic si have the same hub. im gonna double check.
SlapSmak
Dec 28, 2009 06:29 PM
PaChiLa Leader
Feb 18, 2009 05:21 PM
kornerk12
Jun 10, 2007 10:30 AM
redman223
Apr 30, 2007 02:36 PM
Hemix
10
Mar 5, 2007 06:12 PM
