oil light when i break!
hey b18ers i got a b20b in my ef and just recently when i break hard my oil light turns on but soon goes away. i also found out that 2 of my spark plugs have oil in them! and when im in a gear goin down hill without pressing the gas my check engine light goes on and stays on. plz help. thank you
Your oil is low, if your really braking hard or turning hard you shoud look into a baffled oil pan. Password JDM sells a baffle kit. As for the code, next time it happens, don't shut the car off until you pull the code.
change your valve cover gasket and spark pluck seals... this will stop your apparent oil leak and then due an oil change and fill your oil to the correct level... and while you have the valve cover off change the dizzy o ring the cam cap and the two cam seals... and check the helms for all the propper locations to add honda bond too... this will be a $60 fix and you can get everything you need at honda... just ask for the 2000 crv parts and you will be straight
Mr. Samurai
10
Feb 28, 2005 05:59 PM
