REBUILDING MY BLOCK
Old Jan 21, 2010 | 07:14 PM
illestpnoy's Avatar
Default REBUILDING MY BLOCK
i need help guys. i got b18b motor im thinking of rebuilding the block.. the problem is i remove the piston and mixed all the connecting rod caps. does it really matter where to put it since im replacing the rod bearing with ACL. and ive noticed that one of the CAP was upside down and i dont know where to put it?
Old Jan 22, 2010 | 07:37 AM
illestpnoy's Avatar
Default Re: REBUILDING MY BLOCK
any1guys i need help
Old Jan 22, 2010 | 11:50 AM
all-mtr-teg's Avatar
Look at the numbered marking on the sides, the rod will have half of the number on it and the cap will have the other half. Try to match up the markings. If that doesn't work, have your machinist recondition the rods so your big bores are true and weight matched.
Old Jan 22, 2010 | 07:18 PM
illestpnoy's Avatar
ive notice that but does it money if i switch around the piston
Old Jan 22, 2010 | 08:56 PM
What?
Are you asking if it matters which rod and piston combo goes to which cylinder in the block? Yes it does matter, since the rotating assembly is balanced from the factory.
MEn'MYEK
Apr 23, 2012 12:23 AM
DawgC2
Engine Management and Tuning
Jan 2, 2012 11:38 AM
RyanA
Jul 17, 2007 04:14 PM
b18sihatch
Apr 18, 2007 06:56 PM
tegsol1
Apr 11, 2003 04:51 PM
