no fuel power
Old Jan 21, 2010 | 06:55 PM
kike1994's Avatar
Default no fuel power
i have a 1991 honda civic hatchback that has about 147000 miles. the problem is i left the car parked for 8 days cause im a truckdriver. i got home today and when i went to start it it wouldnt start. then it started butwhen i gave it fuel nothing happened and it would die. i turned it on again and it stayed one for about 5 to 10 seconds and then it would die. please help. car has new fuel filter, spark plugs, wires distributer cap, and main relay.
Old Jan 22, 2010 | 12:42 AM
TeamRedline89Hatch's Avatar
Default Re: no fuel power
Throwing a Check Engine Light?
Old Jan 22, 2010 | 03:35 AM
kike1994's Avatar
no check engine light
Old Jan 22, 2010 | 04:30 AM
fasthatch95's Avatar
r u getting gas,fuel pump,or do u have gas in your car?
Old Jan 22, 2010 | 05:27 AM
~sp33~'s Avatar
EFB055
It does sound like you're out of gas.
Old Jan 22, 2010 | 01:17 PM
LittlesilverEF's Avatar
I have the same problem! I sprayed starting fluid in the intake manifold and it would run as long as I sprayed it but would die shortly after. I have a new fuel pump and filter.
Any help?
Old Jan 22, 2010 | 01:32 PM
brownsEF's Avatar
maain relay
Old Jan 22, 2010 | 10:24 PM
kike1994's Avatar
thanks for all ur sugestions. changed the fuel pump and now it works great
ef roni
Nov 12, 2008 10:34 PM
aptyk88
25
Sep 11, 2008 10:14 AM
SOHC_civic_si
36
May 21, 2008 07:31 PM
maxxd97
Apr 23, 2004 06:49 AM
Tij
Sep 2, 2002 04:49 PM
