Need a brake upgrade
Old Sep 4, 2002 | 08:52 PM
twitchm80's Avatar
Default Need a brake upgrade
I have a 95 EG DX coupe. I heard that GSR calipers swap on, but never saw anything on this swap, but if anyone has this how much better did it stop, cause i am thinking of going willwood, or baer, but not sure, i am not a newb, but i don't know **** about brakes only going foward quickly not so much about stoping, so ANY info would be great, experiances, prices, where to buy them, anything will help, and btw I did a search did not find much so maybe this thread can help other make decions as weill THanks for any input guys...
Old Sep 4, 2002 | 09:03 PM
Rratedcivichatch's Avatar
Default Re: Need a brake upgrade (twitchm80)
my car wouldnt stop for crap with my cx brakes with the itr motor. so i swapped to gsr bb, m/c, prop. valve, and the 4 disc conversion with EBC greenstuff pads and it stops more than i need. it was a good invesment. i spent about 850$ all together for everything.
Old Sep 4, 2002 | 09:09 PM
PhuckinHondas's Avatar
i got a 93hb si did a gsr brake conversion
i was very pleased with the results i havent even changed the booster or m/c
i paid 100bucks for the knuckles and calipers with the upper control arm on(didnt need it but it was in better conditon then mine so i put it in
then i got zimmerman crossdrilled rotors and the pads
Old Sep 4, 2002 | 09:16 PM
twitchm80's Avatar
what do you need for the swap, cause i have a dx, just teh knuckles??
Old Sep 5, 2002 | 07:47 PM
twitchm80's Avatar
anyone .......anyone........anyone.......
Old Sep 5, 2002 | 09:16 PM
Kamin's Avatar
it depends on where you look
the best bet would be a local junkyard
im gonna give a little advice tho, if you just upgrade to GOOD pads, new rotors and some fluid with a high boiling point, it should be all you need
im running axxis ultimate pads, ate superblue racing fluid and brembo blank rotors.
it stops hella quick
RACE2WARPED
27
Nov 4, 2010 12:36 PM
mr.toaster
Mar 21, 2009 09:43 AM
TedR719
Jun 23, 2004 11:08 AM
TruePlayaz114
Feb 24, 2002 08:01 PM
Yellow Dragon
Jun 7, 2001 08:15 PM
