Need a brake upgrade
I have a 95 EG DX coupe. I heard that GSR calipers swap on, but never saw anything on this swap, but if anyone has this how much better did it stop, cause i am thinking of going willwood, or baer, but not sure, i am not a newb, but i don't know **** about brakes only going foward quickly not so much about stoping, so ANY info would be great, experiances, prices, where to buy them, anything will help, and btw I did a search did not find much so maybe this thread can help other make decions as weill THanks for any input guys...
Re: Need a brake upgrade (twitchm80)
my car wouldnt stop for crap with my cx brakes with the itr motor. so i swapped to gsr bb, m/c, prop. valve, and the 4 disc conversion with EBC greenstuff pads and it stops more than i need. it was a good invesment. i spent about 850$ all together for everything.
i got a 93hb si did a gsr brake conversion
i was very pleased with the results i havent even changed the booster or m/c
i paid 100bucks for the knuckles and calipers with the upper control arm on(didnt need it but it was in better conditon then mine so i put it in
then i got zimmerman crossdrilled rotors and the pads
it depends on where you look
the best bet would be a local junkyard
im gonna give a little advice tho, if you just upgrade to GOOD pads, new rotors and some fluid with a high boiling point, it should be all you need
im running axxis ultimate pads, ate superblue racing fluid and brembo blank rotors.
it stops hella quick
RACE2WARPED
27
11-04-2010 12:36 PM
mr.toaster
03-21-2009 09:43 AM
TedR719
06-23-2004 11:08 AM
TruePlayaz114
02-24-2002 08:01 PM
Yellow Dragon
06-07-2001 08:15 PM
