2001 Accord V6 Auto Tranny problem
Old Jan 21, 2010 | 12:13 PM
Rok_Stok's Avatar
Default 2001 Accord V6 Auto Tranny problem
It shifts hard from 1st to 2nd.
Also, when I put it in Park, the RPMs go up to about 3k, but not when I put it in drive.
Old Jan 21, 2010 | 01:17 PM
PilotOnDubs's Avatar
Default Re: 2001 Accord V6 Auto Tranny problem
need more info..
but you may have an idle issue such as a bad idle air control valve...
or you may have a bad transmission...or both...
98-02 accords have those common problems
Old Jan 21, 2010 | 03:19 PM
YeuEmMaiMai's Avatar
time for a new transmission......rebuild or replace is going to run about $2500 to $5K
Old Jan 21, 2010 | 08:01 PM
Rok_Stok's Avatar
I know the hard shifting is from worn down clutch packs, but the revving in Park is what I don't get. If it were a bad IACV, I'm pretty sure it would do it in gear also. My automatic Prelude did when my IACV came off the intake manifold one time (thanks to a careless technician).
Old Jan 21, 2010 | 08:10 PM
not all the time..ive seem the idle fluctuate in park and when you shift the transmission in drive the idle steadies...
Old Jan 22, 2010 | 06:01 PM
Spavarious's Avatar
New User
I've been told that my 01 accord has a "sticky valve" and that is what causes the rough shift in mine. The dealership told me that I need to have them clean out the fuel system...
Old Jan 22, 2010 | 07:47 PM
Rok_Stok's Avatar
So is this a threadjack because your fuel system has nothing to do with your transmission. Your valves are inside your engine, that would not cause a hard shift.
Anyways, yes these transmissions are pretty defective, notorious, whatever you want to call it.
Old Jan 23, 2010 | 04:53 AM
tamadrummer1120's Avatar
well there is also shift valves inside an auto trans, and if they are sticking, it may cause the transmission to hesitate on the shift.
Old Jan 23, 2010 | 07:44 AM
Rok_Stok's Avatar
Yeah, but how would cleaning your fuel system clean the valves inside your transmission?
Anyways, it's my mom's car I'm talking about, and she takes it to the dealership for everything. I was just wondering if anyone has experienced the same problem.
salgiosa
Apr 18, 2018 03:11 PM
bestofthe80s
May 7, 2017 05:21 PM
dhoff024
Jul 23, 2015 02:15 PM
graveltravel2
May 3, 2009 06:12 AM
Chief Wenceslaw
Sep 29, 2006 10:03 AM
