Transmission & Drivetrain Gearboxes, Differentials, Clutches
Gearbox problem..Ctr EP3
Old Jan 17, 2010 | 01:00 PM
Marxx 1982's Avatar
Default Gearbox problem..Ctr EP3
So the noise I’ve been hearing. It’s when you are doing engine braking mainly, or if you are coasting along doing 30 in 3rd. Each time you let the momentum of the car turn the engine the noise get audible. It sounds a bit like a grinding noise, possibly bearings. If you just gently touch the accelerator it almost disappears..I heard that it is possible that the bearings are making noise(Input shaft bearings)if someone had a similar problem?Car is Civic Type R Ep3 2004 95.000km..6 speed..
Old Jan 29, 2010 | 08:41 PM
acuratl6mt's Avatar
New User
Default Re: Gearbox problem..Ctr EP3
if you get out of gear can you hear the noise? ive been having the same issue after i had my 3rd gear TSB done. I drive an acura tl and when i do the same thing i can hear it usually when my RPM hits around 2000 - 1500 RPMs. I took it in twice and the tech does not know what it is. Can you still hear this after the car warms up? for me the noise is not severe after the car has warmed up.
Old Jan 31, 2010 | 10:00 AM
Marxx 1982's Avatar
Sound like this?
http://www.youtube.com/watch?v=95rch...layer_embedded
Old Feb 3, 2010 | 11:36 AM
acuratl6mt's Avatar
New User
Marxx, your clip is not playing.
Old Feb 3, 2010 | 02:58 PM
acuratl6mt's Avatar
New User
ok i got the clip to work but couldnt really hear anything. ill check it when i get back at home. Im using my work computer so cant really blast it.
Old Feb 4, 2010 | 04:24 AM
Marxx 1982's Avatar
Pump up the volume on speakers..
Each time i release the akcelerator i hear the noise..
Old Feb 12, 2010 | 02:15 PM
Marxx 1982's Avatar
Bump!
Old Feb 24, 2010 | 03:35 PM
Marxx 1982's Avatar
Any?
Old Mar 3, 2010 | 05:42 AM
boxxy's Avatar
New User
Marxx... I have exactly the some problem mate... you are not alone. Honda have had my car 3 times..... yes 3 times and told me there is nothing wrong and the tech cannot hear anything.... I had to take the woman on the customer service desk out in the car to prove I wasnt hearing things.
Have you found out whats causing the problem?
Mine is going to another garage shortly where they are going to check the Gearbox. I have heard that a cracked engine engine mount can cause a very similar noise. So its worth checking both.
If you find anything out... let us know.
Mart
Old Mar 4, 2010 | 05:56 PM
Marxx 1982's Avatar
Mart
Check this!..http://civictype-r.co.uk/forum/viewt...?f=43&t=200949
mcfadden20
Dec 17, 2012 07:18 AM
h0ndaSi
Honda Civic (2006 - 2015)
13
Oct 30, 2012 04:56 PM
xod
Oct 25, 2007 07:09 AM
cvstrat
Oct 27, 2003 10:01 AM
