Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
04 Accord k24 with 116k what needs checked or replaced?
Old Jan 11, 2010 | 09:52 AM
pumafeet10's Avatar
Default 04 Accord k24 with 116k what needs checked or replaced?
So i have an 04 accord with the K24 and i have about 116,000 miles.
I have changed the transfluid, oil when recommended but wasn't sure what really needs done besides the basic checking of suspension, axles.
When is the timing chain supposed to be changed if at all?
Any other maintenance that would be recommended or preventative for a all highway car?
thanks for the help
Old Jan 11, 2010 | 05:54 PM
KWayRacing's Avatar
Default Re: 04 Accord k24 with 116k what needs checked or replaced?
Change the spark plugs, Drive belt, and coolant and you should be up to par on maintenance. I am assuming that you change you cabin air filter along with your engine air filter. THe timing chain does have an inspection cover but unless you are having issues then I would not check it. The best maintenance for the timing chain is regular oil changes.
Old Jan 11, 2010 | 07:57 PM
pumafeet10's Avatar
thanks for the info on the timing chain, i knew it had very different maintenance approach then a regular timing belt.
Ill have to ask him if the plugs have been changed
leftie
Dec 23, 2013 07:46 AM
rileyparrish
Mar 4, 2010 09:00 PM
chevydriver
Aug 26, 2008 07:46 AM
Two400
Jan 22, 2008 04:10 PM
67coronet383
Dec 4, 2007 04:27 PM
