accord engine problems
Old Aug 22, 2008 | 09:29 PM
chevydriver's Avatar
Default accord engine problems
my ol lady has 2000 honda accord 2.3l lx. it bogs at WOT and idles wierd if it don't stal. any ideas?
Old Aug 23, 2008 | 06:11 AM
fishaholic's Avatar
Default Re: accord engine problems (chevydriver)
Lots of miles? Have you thought about routine stuff? Fuel filter, tune-up. There's good info in the FAQ section about eratic idles.
Old Aug 23, 2008 | 06:50 AM
GhostAccord's Avatar
When was the last time a full tune-up was completed on this car?
Oil & Oil Filter -
Air Filter -
Fuel Filter -
Distributor Cap & Rotor -
Spark Plug Wires -
Spark Plugs -
Old Aug 23, 2008 | 08:41 AM
Default Re: accord engine problems (GhostAccord)
just put this moter in car because girlfrind bought it before i looked at it and piston rings were shot. so just put in cAR NEW PLUGS AND WIRES, CAP &ROTER NEW MAP. THOUGHT IT WAS ECU because timing is off about -10 deg. checked in base timing mode. changed ecu was not problem. now i'm out of ideas.
Old Aug 23, 2008 | 08:53 AM
Mr Yamada's Avatar
you state that the timing is off 10 degrees.
Have you checked to see if the timing belt was installed one tooth off from proper timing?
Old Aug 23, 2008 | 08:58 AM
Default Re: accord engine problems (Mr Yamada)
No, but motor came out of a running car i was told when bought it.
never looked at timing belt before instaled.
Old Aug 26, 2008 | 07:46 AM
checked timing belt marks all line up. hooked scanner up and the ELD says 99% map reading even when unhooked. throttle at 81% and goes down when you push down. I replace throtle body already and no change stumped any ideas
pumafeet10
Jan 11, 2010 07:57 PM
sonny0330
Jun 3, 2008 02:52 PM
67coronet383
Dec 4, 2007 04:27 PM
jizzer671
Jun 2, 2005 12:40 AM
Turbo_y8
May 24, 2005 07:06 AM
