removing abs on a 93 del sol.....
Old Jan 11, 2010 | 09:32 AM
H23_del_soul's Avatar
Default removing abs on a 93 del sol.....
I read a few threads on removing the abs on tegs, but I have not seen one for a sol yet. Is there any difference, and do I need the same 40/40 prop. valve?
Old Jan 11, 2010 | 09:48 AM
MonkeyMagic's Avatar
Default Re: removing abs on a 93 del sol.....
basically the same combination of eg brake lines and crap.
Old Jan 11, 2010 | 10:35 AM
do you need to swap to rear discs to do it? Are there any good threads I am missing for a rear disc conversion?
Old Jan 11, 2010 | 12:55 PM
thumper64's Avatar
If you're switching to non-ABS, you may as well upgrade the prop valve even if you don't plan to put disk brake in until later.
DA non-ABS or DC RS brake booster and master cylinder, or you can use adapters and bend your lines and make your current one work. $10-100 for the former, <$20 the latter
DA 4040 prop valve. Usually around $40.
new brake lines.
rear disk conversion (you don't need the trailing arm, just the hub part on there)
line wrenches, also known as tubing wrenches. They look like this and make your job 9948584535945435x easier: http://www.bracketracer.com/nova/cppfdb/mc/cppfd123.jpg
These are like $15 at Autozone for a set.
Don't mess with your front brakes, you already have Integra sized ones.
You could upgrade to AN fittings, but that will require adapters and a flaring tool and it's not necessary at all.
If you need a 4040 prop valve or want a cheap (13/16) non-abs master cylinder/booster PM me.
Old Jan 11, 2010 | 02:38 PM
94EG8's Avatar
Seagull Management
If its a '92 - '95 and it has ABS its already got rear discs and larger EX front brakes. You need to use non ABS lines and the 7/8 MC off a non-ABS EX coupe along with a 3030 prop valve which can be had from any CX/DX/VX/non-ABS LX/non-ABS EX.
Old Jan 11, 2010 | 03:38 PM
z6htch's Avatar
I did not know 93' Del Sol's came with ABS?
Old Jan 11, 2010 | 05:25 PM
thats what I was starting to think. would it have even come with it? I still want to do the rear disc swap either way.
Old Jan 11, 2010 | 06:09 PM
z6htch's Avatar
If you don't see a bunch of brake lines running over to a box on the pass side right behind the headlight (by your air intake box) then you do not have abs.
I didn't have abs on my 93' Del Sol Si. Hope this helps
Old Jan 11, 2010 | 06:10 PM
z6htch's Avatar
Also if yours is an Si, it should have rear disc unless someone really flucked up. The Del Sol S didn't come with rear disc.
Old Jan 12, 2010 | 09:58 AM
Ok, looked at it today and damn....I have rear discs.... Been almost 8 months since I messed with it and I just remembered wrong. So should I have ABS or no?
Old Jan 12, 2010 | 10:02 AM
redrocket_ej1's Avatar
Old Jan 12, 2010 | 10:21 AM
going to look now...
Old Jan 12, 2010 | 11:05 AM
dpetro1's Avatar
i dont think abs was avialable in 93. pretty sure 95+ vtec trim had abs though, and possibly some 94's
Old Jan 12, 2010 | 01:58 PM
94EG8's Avatar
Seagull Management
ABS was available on '93 - '97 Del Sol Si's.
Old Jan 12, 2010 | 03:09 PM
dpetro1's Avatar
hmm found this vin decoder, maybe that will help as well
Example Description
Vin #
J ╗
H ] - JHM = Honda Motor Co. passenger car
M ╝
E ╗ EG1 = D15B7 (93-95 S)
G ] - Engine: EG2 = B16A2 (96-97 VTEC), B16A3 (94-95 VTEC)
2 ╝ EH6 = D16Y7 (96-97 S), D16Y8 (96-97 Si), D16Z6 (93-95 Si)
1 ] - Body/Transmission: 1 = 2-door manual 5-speed 2 = 2-door automatic
6 ] - Vehicle Series: 4 = S 6 = Si 7 or 9 = Si with ABS, or VTEC
? ] - math check digit
R ] - Model Year: P = 1993, R = 1994, S = 1995, T = 1996, V = 1997
S ] - Assembly Plant: C = Sayama, S = Suzuka, T = Tochigi
0 ╗
0 ║
5 ] - Serial number, based on the sequence off the
7 ║ production line
9 ║
3 ╝
Old Apr 3, 2020 | 01:08 PM
Jeff Shumate's Avatar
new brake lines.
Old Apr 3, 2020 | 04:53 PM
muellersfan's Avatar
What's going on here?
Old Apr 4, 2020 | 06:34 AM
94 Civic Si's Avatar
Premium Member
Loved
Community Favorite
Some serious bumpage!
wstmsol
Suspension & Brakes
Dec 19, 2011 08:43 PM
Wakes4Fun
Jan 29, 2009 10:42 AM
1LowSol
Jan 11, 2009 11:56 AM
itsmejto
Aug 7, 2008 03:10 PM
spooncivic01
Mar 9, 2007 02:51 PM
