5 speed conversion
Old Jan 11, 2010 | 09:18 AM
1999hondaex's Avatar
Default 5 speed conversion
iam putting a 5 speed conversion in a 96 civic the are 2 plugs on the clutch pedal i have no idea where they go, an is the any other wires i need to change
Old Jan 11, 2010 | 09:37 AM
itsnotfast's Avatar
Default Re: 5 speed conversion
One is for cruise control cancel, the other is a switch so the car can not be started without pressing the clutch. I did mine and didn't hook either of them up because I have a remote start and as far as the other one goes, if you dont hook it up it will not shut off the cruise off when you press the clutch and the car will rev until it hits rev limiter or you hit the brake pedal.
Old Jan 11, 2010 | 10:51 PM
so what do i hook these wires to an someone told me that there are some wires in the steering column i have to unhook
Old Jan 11, 2010 | 11:55 PM
Linked's Avatar
you remove the automatic shifter in the center console and splice the 2 connectors into the big plug thats in there
the clutch safety switch goes into the thick black/red and black/white wire
the cruise control cancel switch connects to the pink wire and the other goes to a ground
RustyE.G.
13
Oct 1, 2018 11:13 AM
melissashelton1
Dec 26, 2009 04:37 AM
Tonyl507
Jul 13, 2006 06:31 PM
helmet_mobn
Jun 15, 2006 04:37 PM
HalfAnP
Apr 10, 2005 01:20 PM
