What ecu for my B16a2 swap??
if you remember I have the 98 spec RHD ITR. I have been going back and forth on what to do motor wise for some time. I am now in the position where I just need to car drivable. I picked up a complete B16a2 swap from a wrecked 2000 civic SI today with 110k miles on it. I have the RHD harness that came with the caR. I also received the ECU from the 00 SI which I believe to be a P2T ecu.
Will this ECU and Harness work with the car?
If not what do I need to switch these out with or what ELSE do I need to make this work?
Thanks for the help folks!
Steve
Steve
I think you will need a harness conversion to make that work.
if I am not mistaken 98 type R would be OBD2A and 99-00 SI ECU would be OBD2B
I think this is what you need to run that ECU in your ITR
http://www.phearable.net/shoppingcar...ess-p-118.html
but you might want to do some more research into this or wait for some more opinions as I am not 100% sure.
SwapedEX
30
Aug 10, 2006 07:21 PM
