whats the right compression for a 2000 s2000?
My friend just told me that she thinks that she might have blown the head gasket on her car,she said some mechanic did a compression test and she got a 120 but she doesn't really know a lot about her car,so were gonna go do another test later,what is the compression suppose to be on all 4 cylinders?
if any of the cylinders are at 120PSI, somethings horridly wrong.. even if its uniformly 120PSI across there is something wrong (assuming the comp tester is accurate)
could be a number of things, just to list a few:
blown headgasket, bent valves, piston rings failure, scores in the cylinder walls, and so on and so forth. pick your poison ! good luck with the repairs
While the number is pretty low, I suspect the person who made the test, or the gage.
I should be pretty obvious performance wise.
Is it burning a lot of oil, or making smoke ?
Maybe I read the post wrong, I wasn't saying "if you have 120psi all across, then these are the reasons" I was merely stating the possible reasons for any 120psi reading whether it be across, in 2 cylinders, or in a single cylinder.
she gave up on it.
http://hondamarketplace.com/showthread.php?t=2708510
ej6kid
Dec 12, 2010 07:22 AM
Boostn B20
11
Nov 27, 2008 01:22 PM
