93 civic idle issue HELP :|
Old Jan 7, 2010 | 06:19 AM
ennohohbee's Avatar
Default 93 civic idle issue HELP :|
Okay so i have a 93 civic with a jdm b16a swap, and it' idling rather high (2700 rpms when cold) .
But,if you take your finger and plug this hole inside the throttle body (there are 2, the one on the bottom left is the one im plugging) then it idles perfect....what is the problem? i JUST replaced the whole throttle body with sensors.AND my 2nd question is i got an IACV off a 94 integra LS, and it wont fit on my intake mani, whats up with this?
Old Jan 7, 2010 | 06:55 AM
shoklid's Avatar
Default Re: 93 civic idle issue HELP :|
intake mani vac leak
Old Jan 7, 2010 | 06:58 AM
ennohohbee's Avatar
iv looked for leaks and cannot find any ;(
Old Jan 7, 2010 | 11:52 AM
grant97teg's Avatar
could be your fast idle valve or something in your map sensor possibly. double check your throttle cable is installed properly
Carpoollane
Sep 8, 2018 03:08 AM
techsupport
38
Sep 28, 2016 06:31 PM
jroderick619
Apr 13, 2013 12:07 PM
jefe
13
Jan 11, 2011 09:21 AM
Prevail
Feb 12, 2005 06:02 PM
