idle.. throttle body.. intake manifold..
sup guys.
i got a 93 civic D15B7 motor...
i just cleaned out my THROTTLE BODY and after a good warm-up i noticed my idle sits in between 0-1rpm (.5rpm) during the warm-up it'll sit at 1rpm or just a tad bit if anything..
and before i cleaned the throttle body it would idle at either 1rpm or 2rpm
my QUESTION IS.
What is the NORM for Idle?
Would i have to clean the intake manifold also?
my QUESTION IS.
Re: idle.. throttle body.. intake manifold..
do you mean 0-1k rpms? and .5 as in 500 rpms?
my 90 civic si with a Zc sohc idles around 500-550rpms. i perfer the lower rpm like that, but it can be annoying also.
and in the haynes manual my 97 civic with a d16y7 is supposed to idle around 700-750 rpms.
sup guys.
my QUESTION IS.
my QUESTION IS.
and fixed my idle problem.
i cleaned out my throttle body and iacv and played with the adjustable screw.. it was tight the the max.
it idles (from the looks of it) 760 - 800rpm.
thanks for the reply guys!
just wondering now..
does your fuel gauge fluctuate up and down while drinving? and when you stop it finally shows the true reading of the fuel level??????
yeah i meant to put that. i was too lazy to type out the correct readings in hopes that you guys would catch what im saying. but yeah i fixed my problem..
does your fuel gauge fluctuate up and down while driving? and when you stop it finally shows the true reading of the fuel level??????
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/diy-low-fuel-light-not-working-fuel-gauge-isnt-accurate-96-00-a-3131993/
import-tooner
07-03-2013 07:49 AM
