Suspension & Brakes Theory, alignment, spring rates....
Vacuam pump to bleed brakes?
Old Jan 6, 2010 | 10:00 PM
Race Egr's Avatar
Default Vacuam pump to bleed brakes?
Has anyone ever tried using a vacuum pump like this to bleed brakes:
Just curious, as I have an old one sitting around.
Old Jan 7, 2010 | 08:39 AM
darkenedsol's Avatar
Default Re: Vacuam pump to bleed brakes?
No, I haven't, but I have used several different vacuum pumps to bleed brakes-the two common deisgns are either a hand-operated vacuum pump that can also create vacuum to test/diagnose sensors, valves for engine diagnosing. The other common type attaches to an air compressor and uses the venturi principle to draw fluid out of the calipers. Hope this helps!!!!
Old Jan 7, 2010 | 10:38 AM
zakelectric's Avatar
New User
Can't say I have, but I don't see why it wouldn't work
Old Jan 7, 2010 | 12:11 PM
kommon_sense's Avatar
Should work just fine. Is it adjustable? If it pulls too much vacuum, it may just collapse the hose or pull air from around the bleeder screw. You might have to get creative and rig up a way to bleed off the excess vacuum.
Old Jan 7, 2010 | 12:22 PM
.Manny.'s Avatar
Touching My Member
I've used my hand-op pump, nothing that big though
Old Jan 7, 2010 | 04:21 PM
Race Egr's Avatar
yea, I think im gonna try hooking a tank in between it like the hand operated vacuum pumps. Its not adjustable ,but there is two ports on it so I think I would be able to just open one of them slightly to adjust it. I will report back on how it works.
teler86
Feb 25, 2006 07:26 AM
ibe2fly
Jul 7, 2005 01:54 PM
sleepyEK
Nov 11, 2004 12:10 PM
hellas
Jun 10, 2003 05:37 AM
DLB1994
Aug 28, 2002 06:53 PM
