My baby won't start, this is crazy??
Old Jan 6, 2010 | 06:59 PM
92dadan's Avatar
Default My baby won't start, this is crazy??
Ok I know I have power, fuel pump turns on brand new 255. Starter works took it out and checked it, plus you can hear it trying to do something. but the car will not turn over? I just put this motor in and can not figure this out. You can hear the starter engage and click but won't turn the motor over. Any help would mean the world.
Old Jan 6, 2010 | 07:00 PM
D16SiHatch's Avatar
Default Re: My baby won't start, this is crazy??
have you had the engine running at all yet? check to see if the crank is spinning over freely
Old Jan 6, 2010 | 07:01 PM
92dadan's Avatar
The crank does spin no prob, power fuel, spark. no i have not had this motor running yet.
Old Jan 6, 2010 | 07:04 PM
D16SiHatch's Avatar
so when you had the starter out i assume you tested the solenoid right, and not just the starter motor seperate? if it functions properly outside the car, and you're getting power in the car from the trigger wire, then theres really no reason it shouldnt be turning over.. hmmm. are your tranny to chassis, and engine to chassis grounds in use and intact?
Old Jan 6, 2010 | 07:05 PM
92dadan's Avatar
I have no way of doing that right now, I have the breaks off. But its weird, I hear the starter engaging, click clack click. Power to everything, but it wont turn the motor over, is it a bad battry, or bad starter. I took the starter out and it pushed out and spun, so it should be good.
Old Jan 6, 2010 | 07:06 PM
92dadan's Avatar
Yes all grounds are there plus i added two more on the other side. getto grond block lol.
D16SiHatch's Avatar
do you have a multimeter? check the voltage that you're getting from the battery. maybe its just real low
Old Jan 6, 2010 | 07:09 PM
92dadan's Avatar
I have the battry hooked up to a charger so im getting 12+ volts like 13.
Old Jan 6, 2010 | 07:13 PM
D16SiHatch's Avatar
is it like a light clicking noise or a hard clunk like its hitting the flywheel and not spinning. if it's clicking and not doing anything then that really sounds like the solenoid is acting up. they can be difficult to diagnose. work one second, then not the next.
Old Jan 6, 2010 | 07:16 PM
92dadan's Avatar
Hard clunk plus a click lol. It sounds like the starter is hitting the fly wheel but not moving it. The teeth on the starter and on the fly wheel are not like brand new but there not missing any teeth, show wear but nothing crazy.
Old Jan 6, 2010 | 07:28 PM
D16SiHatch's Avatar
and you're certain you've got the correct starter on there? i'm running out of idears here :/ lol
Old Jan 6, 2010 | 07:30 PM
92dadan's Avatar
I know lol. Unless there is a differt starter on a d16z6 then a d15b8?
Old Jan 6, 2010 | 07:54 PM
D16SiHatch's Avatar
i don't believe they are different. auto and manuals trans starters are different though. for b-series anyway i know that an auto starter will not line up to a manual trans, so i imagine the same thing may be true with d-series. i doubt thats your problem though.
Old Jan 6, 2010 | 08:59 PM
shogee's Avatar
sounds like a battery
papagnoj
Jan 6, 2011 04:49 PM
civic89si666
Sep 27, 2006 02:54 PM
98gsrTEG
Aug 1, 2005 06:30 PM
flip1199
Feb 21, 2005 03:52 PM
rexheadb16a
Jun 4, 2003 05:30 PM
