How to wire a B18 in a civic?
Got a 96 civic ex coupe (D16Y8 Vtec) manual trans. im Looking foward to do a B18 swap dont now if vtec or not cuz i dont have the motor yet I just want to know how hard the swap is going to be and how to do it. I dont know nothing about B18's. what do i need to performed the swap?, Can i still use my harness?. what kind of motor mounts do i need? what ecu do i need, is the p75 the one for non vtec B18's? im i using the B18 axles? any help appreciated... And please try to post some pics to make it easy on me specially of the wiring process....Thanks
The FAQ thread is your friend,
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/faqs-frequently-asked-tech-questions-1998336/
You can use your harness, since you have an ex I believe everything is already wired up for you. Plug and Play with the exception of a few wires depending on what motor you go with.
You`ll need:
Driver side post mount from a 99-00 si
Stock tranny mount
Rear L Bracket from 99-00 si
Front tranny torque mount from bseries
B series shift linkage, axles, coolant hoses, throttle Cable, fuel line (from filter to rail)
CRV AC bracket if you want to keep it
ECU
You`ll need:
Stock tranny mount
ECU
ToTriggerHappy
11
Oct 13, 2010 02:48 PM
esurds
Jun 25, 2009 06:03 AM
MaintenanceWhore
May 29, 2005 06:20 AM
