need procedures to trouble shoot overheating
Old Jan 5, 2010 | 04:53 PM
johnny090881's Avatar
Default need procedures to trouble shoot overheating
OK, my friend has a 91 Accord and his car been overheating he recently replaced the thermostat, radiator cap, radiator and added new coolant. There's no signs of a blown head gasket or any coolant in the block and to top it off there's no leaks from any hoses or coming from the water pump. Fans do come on. The only things I can think of is the maybe the coolant sending unit is not working properly or at times or maybe even the timing might be off. Any input would be greatly appreciated.
Old Jan 5, 2010 | 06:34 PM
ricebike's Avatar
Default Re: need procedures to trouble shoot overheating
did he "burp" the system correctly? made sure no trapped air pockets in the system?
did he put the thermostat backwards? or w/ the air/jiggle valve upside down, causing air pockets?
that's the only 2 things i can think of if you guys ruled out the other stuff u mentioned <shrugs>
ignition/emissions wise maybe something's causing a lean condition... running leaner will make it overheat; how's the egr valve?
Old Jan 5, 2010 | 07:56 PM
Atreidies's Avatar
Is the water pump good?
Tunedwhitey
Honda CR-V & Element
Jun 26, 2018 11:59 PM
Rtboy10
Jun 27, 2009 08:04 AM
turbohb21
Aug 7, 2007 08:43 PM
Nameless Warrior
10
Dec 16, 2006 07:27 AM
drumsy
Sep 12, 2002 07:14 AM
