topping off coolant
topping off coolant
Hey guys I just recently put on a slim fan removed my radiator hoses to replace them, do you guys think it would be fine to top the coolant off or should I get it flushed ect so I do not risk getting air bubbles. If anyone can help me I would greatly appreciate it.
Re: topping off coolant
don't risk getting air in coolant, it could lead to other problems. Just bleed it out at the bleeder screw, or run the car without the radiator cap to get any air that may be trapped.
so...you did allow air to enter your cooling system..it must be bleed. no big deal. no way you could have avoided this situation.
cold motor...cap off...rasie front end as high as you can go (to make it the highest point above the motor. "tech tip this is not an actual crictical step") and start vehicle.
allow vehcile to get normal temp with cap still off and monitor temp. if temp rises turn the car off and wait. keep adding coolant the best you can. avoid the best you can cold coolant into a hot overheating radiator.
some vehcils come with a bleeder screw next to yoru thermostat. same idea just open bleeder screw until coolant comes "streaming" out.
he is right but it sounds weird the first couple of words. what he means is that you dont want to drive around with air bubbles in yoru cooling system because your water pump is not an air pump. it can only move liquids. if air reaches yoru water pump it will stop pumping resulting in an overheating condition.
Bill Leland
06-12-2014 02:29 PM
fast+forward
01-29-2007 03:13 PM
