dust ring
Old Jan 5, 2010 | 02:09 PM
martn53's Avatar
Default dust ring
wen removing the dust ring on the spindles,do u just remove the rubber ring ?
Old Jan 5, 2010 | 03:48 PM
D16SiHatch's Avatar
Default Re: dust ring
this is what you take out
Old Jan 5, 2010 | 04:11 PM
blasterman87's Avatar
its the metal ring, not plastic
Old Jan 5, 2010 | 04:35 PM
martn53's Avatar
so u dont have to take out the rubber thing?the metal ring thats around where the axle goes in?
Old Jan 5, 2010 | 05:13 PM
u take out whats in the pic, its metal
Old Jan 5, 2010 | 05:36 PM
EK_RedSiR's Avatar
X2
Old Jan 5, 2010 | 07:39 PM
hatchet_honda's Avatar
itll be a rusted metal ring you just pop off...done. just look whats in his hand in the picture.
Old Jan 5, 2010 | 08:15 PM
martn53's Avatar
f**k i took the rubber rings off
i didnt know they were alredy removed :/ should i have any problems?
Old Jan 6, 2010 | 06:26 AM
i think thats a seal for the wheel bearing, it will run fine but the bearing will go bad faster due to dust/road dibre
Old Jan 6, 2010 | 07:52 PM
yeahhh you just pryed the bearing seal off...lots of shizz is gonna get in there now..poof no more bearing. so the axle was already installed? if it was spinning freely and no binding then obviously the rings were gone already
Old Jan 6, 2010 | 09:28 PM
EL Vap133's Avatar
Ouch! Why did you pull that off? New install, new knuckles/hubs?
Old Jan 6, 2010 | 10:20 PM
martn53's Avatar
i thought that was the "dust ring" .ya i have an std so i had to upgrade to si's
aWeimaraner
Transmission & Drivetrain
Mar 5, 2009 07:26 PM
Aquafina
Mar 2, 2006 10:33 AM
