Snap ring problems
Old Feb 3, 2006 | 07:08 AM
Aquafina's Avatar
Default Snap ring problems
96 Y7 transmission
Installed SRR FD a couple of weeks ago. Broke axle in trans. Pulled apart, pulled diff apart to pull axle out. Put back together. Did not take countershaft apart.
Replaced snap ring as it was bent.
No burrs in case, case is clean. No burrs on bearings. Snap ring spread open over bearing. 4 case bolts tightened down. Prying the bearing won't do it. Dropping the case onto wood won't do it either.
Took apart and pulled out forks and shafts. Put back together. Still won't do it.
Pulled case apart several times and it just won't snap. Ring width away from the groove.
Old Feb 3, 2006 | 11:03 AM
msmotorsports's Avatar
Default Re: Snap ring problems (Aquafina)
I read your post a few times. I think you are trying to say the case is not going back together. If that is your problem you will just need to play around with it more. DO NOT try to srew down the case hoping it will pop into place. You will just hurt the case doing so. Just make sure the bearing snap ring is 100% open while putting on the case. Just be patient. The cases can be wierd sometimes. On the last 5 tranny's I rebuilt, 3 of them went back on like butter. The other 2 were a bitch getting back on. I have no idea what causes this but its just luck of the draw I guess.
Old Feb 3, 2006 | 11:41 AM
Aquafina's Avatar
Default Re: Snap ring problems (msmotorsports)
The case goes together fine. THE SNAP RING WILL NOT SNAP INTO THE GROOVE.
Old Feb 3, 2006 | 12:48 PM
1fastVX's Avatar
Flip it over and it should pop into the snap ring
John
Old Feb 4, 2006 | 10:35 AM
Aquafina's Avatar
Default Re: Snap ring problems (1fastVX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1fastVX &raquo;</TD></TR><TR><TD CLASS="quote">Flip it over and it should pop into the snap ring
John</TD></TR></TABLE>
Reading owns you.
Old Feb 4, 2006 | 01:33 PM
1fastVX's Avatar
You never said anywhere in you post that you flipped the tranny over. So maybe you need to write things with a little more detail
John
Old Feb 4, 2006 | 01:44 PM
Aquafina's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aquafina &raquo;</TD></TR><TR><TD CLASS="quote">Dropping the case onto wood won't do it either.</TD></TR></TABLE>
Did you think I just picked it up and dropped it?
Old Mar 2, 2006 | 10:33 AM
Circuit Star-29's Avatar
Default Re: (Aquafina)
Bump cause my tranny is doing this now....
SAME THING!!!
85mmek9
Apr 17, 2009 04:49 AM
TB123
Transmission & Drivetrain
Mar 22, 2009 02:36 PM
dohc_profile
Sep 7, 2007 02:24 PM
static-x
16
Aug 1, 2007 12:18 PM
ProjectDarkBlack
May 13, 2007 01:57 PM
