i got a major prob!! help please! oil pressure prob
Old Sep 3, 2002 | 08:40 PM
batboyvaj's Avatar
Default i got a major prob!! help please! oil pressure prob
my car starts and everything. i got a custom setup. t3 off a svo. tial, custom pipes and dp. and everything. the car starts but it idles like crap and we got it down to the oil pressure. the gauge barely climbs. its not even at 10. its a autometer gauge. everything is tapped right. i got a 1/8" male fitting bout 1 1/2" long into the block. a "T" fitting and in the first T i got the oil feed and another 1/8 male adapter to another "T". on the 2nd T i got the stock oil press and the autometer press tapped in. we think it may be the oil feed line. it is barely enough and i have it tapped and wrapped around the oilpan back up the front of the motor into the turbo, its a little tight and making a sharp turn right before it gets to the turbo. you guys gotta help me out here...i'm going nuts....its been 4 days
Old Sep 3, 2002 | 10:30 PM
lucas569's Avatar
Default Re: i got a major prob!! help please! oil pressure prob (batboyvaj)
do not run the car w/ low oil pressure, trust you will roast your bearings if you havent done damage already, more than likely your oil pump went south. thats what happened to me and i roasted my bearings. it wasnt cheap, trust me.
i wish i had an oil psi like yourself to catch it in time. btw can you elaborate on this "it is barely enough and i have it tapped and wrapped around the oilpan back up the front of the motor into the turbo, its a little tight and making a sharp turn right before it gets to the turbo. you guys gotta help me out here...i'm going nuts....its been 4 days"
Old Sep 4, 2002 | 05:21 AM
batboyvaj's Avatar
Default Re: i got a major prob!! help please! oil pressure prob (lucas569)
i meant the line was barely long enough to reach the turbo. i wraped the feed around the bottom of the block and up to the turbo? should having 3 things "T"ed in the block drop my pressure that much? how could my oil pump go bad that fast. its a 2001 gsr with 23k mi on it?
Old Sep 4, 2002 | 05:33 AM
batboyvaj's Avatar
i was just reading some post and they said that my idle pressure should be around 5-10psi? that is what mine is at. so is it normal? what else would cause my car to idle like crap and die? my turbo could be bad too....its off a older ford
Old Sep 4, 2002 | 05:37 AM
batboyvaj's Avatar
i was also reading ANOTHER post and i shouldn't haev my autometer press and stock oil press tapped right?
Old Sep 4, 2002 | 11:20 AM
lucas569's Avatar
it could be your gauge, auto meter isnt known for its high quality, btw you should have 7 psi at idle and about 50 psi by 3000 rpms.
Old Sep 4, 2002 | 12:01 PM
batboyvaj's Avatar
50 even when there is no load on the engine.....(neutral) not moving
Old Sep 4, 2002 | 01:48 PM
batboyvaj's Avatar
i'm beggining to think that my car won't idle because of the fuel pump. i got a airtex inbetween my fuel filter and rail. is that where its suppose to go? i have it hooked up to my stock pump relay. comon guys. help me out....
importdude2000
Jul 6, 2006 04:09 PM
W O T
Jan 29, 2005 08:01 PM
phiberoptik
Aug 7, 2003 09:52 PM
batboyvaj
Sep 4, 2002 12:02 PM
