nitrous problem.
Old Jan 2, 2010 | 11:00 PM
j0keefe21's Avatar
Default nitrous problem.
so i was running my car earlier and all was well then at about 5k it just seemed like my car turned off almost like the ignition cut out... i pushed in the clutch put it in 5th and it was fine. never had this problem b4 when i was spraying... bottle pressure was at about 850 since it was a tad chilly... the car is a d15 with z6 head. basic bolt ons and 50 shot. any help would be much apreciated.
Old Jan 3, 2010 | 09:19 AM
j0keefe21's Avatar
Default Re: nitrous problem.
bump... need to close gap on my plugs maybe?
Old Jan 3, 2010 | 11:23 AM
turbodcxbro's Avatar
Most likely or the N2o just wiped out your plugs due to a bad tune...
Old Jan 3, 2010 | 02:24 PM
Altered_Tom's Avatar
Are you running a B7? I would be scared to spray a stock B7 block
Old Jan 3, 2010 | 02:51 PM
Gunmetal_B20_Hatch's Avatar
any engine management?
How much timing are you pulling when you spray?
Old Jan 3, 2010 | 03:07 PM
VTECROAR96typeR's Avatar
its a sign that you motor is giving you because its getting ready to go
Old Jan 3, 2010 | 03:10 PM
95dxsir2's Avatar
prolly wouln't find help here. try the drag section, and add more detail on your setup
j0keefe21
Jan 4, 2010 06:50 PM
thumbtack
Apr 27, 2005 04:32 AM
jdmcivicferio
Aug 8, 2004 01:38 PM
shift6
Oct 17, 2002 04:49 PM
pstreck
Sep 6, 2001 11:46 PM
