new set-up not running right.
Old Jan 1, 2010 | 05:48 PM
grndcont's Avatar
Default new set-up not running right.
so, i made some changes to the car and now (big surprise) it's not running right.
this is on a built 9:1 b18c1, the ignition timing is right on, i am starting with base maps.
the changes were:
new turbo gt3000 - not a factor (still tuning idel)
s300 upgrade from s200
id750 upgrade from dsm 450's
rewired fuel pump with dedicated 10awg line and relay.
i can get the car to run and idel around 800rpm with a a/f around 15, but to do this i have to set the injector size to 300cc. if i set it at 750 like the injectors are the car goes way lean and dies.
also, when i have it running at 300cc, if i give it any throttle the engine stumbels, like it cant keep up with the extra air. if i lightly give it throttle however, it will raise the rpm smothly.
any ideas? i am fairly sure that the dead time is set correctly. i used tonys sheet, and input the values for 43.5 psi.
Old Jan 1, 2010 | 06:08 PM
bigD's Avatar
Default Re: new set-up not running right.
did you remove the resistor box?
Old Jan 1, 2010 | 06:11 PM
king06's Avatar
X2
Old Jan 1, 2010 | 06:30 PM
grndcont's Avatar
yes. i changed all the injector wiring back to stock.
Old Jan 1, 2010 | 06:42 PM
grndcont's Avatar
well i got it running better now. idel is at 850rpm, vac is at -20, a/f is right at 15:1, EGT is at 600, and oil is at 20psi. also the throttle response is back to normal.
what i did was increase the low cam fuel table values and corrispondingly raised my injector size value back to 750.
Old Jan 1, 2010 | 06:54 PM
grndcont's Avatar
still lots of wiring to clean up before i drive it, plus the whole interior is out. also, these injectors dont seem to want to idel well above 15:1, i thought i heard that they did.
Old Jan 2, 2010 | 11:55 AM
grndcont's Avatar
so i can get it to run good in closed loop, or open loop, but not both. if i am in closed loop and then i select open loop, the car goes way rich. any ideas?
Old Jan 3, 2010 | 06:50 AM
mtber's Avatar
What engine management are you using ?
Do you have a stock narrowband o2 sensor installed as well as a wideband ?
Old Jan 3, 2010 | 07:47 AM
HRTuning's Avatar
Old Jan 3, 2010 | 07:58 PM
grndcont's Avatar
i have the ecu running on the stock o2, and i have a separate wide band o2 for my monitoring. haven't had time for any road testing so there is more to discover.
Old Jan 16, 2010 | 09:51 PM
grndcont's Avatar
nm, fixed.
aznboi_106
11
Jul 12, 2010 03:46 PM
27psi
Engine Management and Tuning
18
Jul 27, 2008 01:00 PM
Black DC2
Feb 28, 2006 07:53 AM
VTgringo
Aug 18, 2003 06:50 AM
scttydb411
May 19, 2003 03:03 PM
