A/C Compressor for LS Swap?
Old Jan 1, 2010 | 05:47 PM
Matt93eg's Avatar
Default A/C Compressor for LS Swap?
Hey guys,
Its time I get A/C back in my car. I haven't had A/C since I did the swap. At the time I was more interested in having a cleaner, less clutered engine bay. After 2 summers I am sick of not having A/C.
SPECS:
-1994 B18B1 Engine
-Car: 1993 Honda Civic EX 2-dr
I have been doing some research but am still kinda lost as to what compressor to use.
As far as the A/C Bracket from what I have searched I can use a 94-97 Del-Sol VTEC compressor bracket or one off a 94-01 CR-V.
As for the compressor I have read where people say use the Integra Compressor, then I have read where the Integra compressor won't work and to use the original D-Series compressor. But, I thought the D-Series compressor wouldn't bolt up to a B-Series bracket?
Any insight on what compressor to get would be great, also let me know if I can use all my other stock D-Series stuff as far as the lines and condensor, etc go. I want to start sourcing parts and get this done in the next few weeks and get it working good before any warm weather starts approaching.
I will also most likely grab the 97-01 CR-V bracket as I will be able to get one from my local Honda Salvage easier than I can get my hands on the Del-Sol VTEC one.
Thanks in advance. Happy new year as well.
Old Jan 1, 2010 | 07:01 PM
thumper64's Avatar
Default Re: A/C Compressor for LS Swap?
The CRV (P7J) or the Del Sol VTEC (P54 I think) AC bracket allows the D series compressor to attach to the B series motor. You can check at junkyards, the CRV one is probably more common. If you can't find one, PM me, I have a CRV bracket sitting behind the seat in my truck...I'll let it go $50 shipped?
You'll use all Civic parts besides the bracket. So, Civic AC lines, compressor, condensor, etc.
Old Jan 1, 2010 | 07:13 PM
Matt93eg's Avatar
Thumper,
Thanks alot man, Very helpful as usual! Greatly appreciated. Now that sounds freaking sweet that I can use the D-Series compressor with either of those brackets. I still have all my old D-Series A/C Parts in my garage. I will check with a friend of mine to see if he just happens to have a CR-V or DOHC VTEC Del-Sol bracket laying around. If not, I'll hit you up via PM.
Thanks again.
Old Jan 1, 2010 | 07:53 PM
thumper64's Avatar
You're welcome and good luck with the project. Your car is a 93, so you may have R12 or R134A depending when it was built since 93 was an odd year. That doesn't get brought up often, so just thought I'd mention it.
ClassyG
Dec 28, 2013 09:01 AM
MShonda
Nov 22, 2010 07:20 PM
davken1102
Mar 18, 2004 09:52 PM
wm5holla
Sep 16, 2003 08:45 AM
