AC Problem.. Help??
AC Problem.. Help??
i have a jdm b16 and the ac bracket that came with it doesnt allow my ac compressor to mount to it. what compressor or bracket do i need?
Red is where the compressor sits and yellow is where the holes are.
The front two holes line up but the back two holes are off, do i need a differant compressor or bracket? the compressor is a stock 94 CX and i assume the bracket is off a jdm civic. are the compressors not the same?
Re: AC Problem.. Help?? (davken1102)
Well you can change the compressor but you will also have to change the lines.
the lines going to the condenser is not going to fit its at a different angle.
IMHO just get the bracket and use your current compressor.. alot less work. given you will have to evacutate the refergerant and then charge it back up which costs $$$$
moz92
08-13-2008 10:55 PM
kenji
15
12-03-2002 02:28 AM
