Classic Hondas All Pre-1988 Hondas.
where is my idle adjustment?
Old Jan 1, 2010 | 08:26 AM
dangercartjason's Avatar
Default where is my idle adjustment?
ive got an 86 crx. 1.5. on the carburetor, where is my idle adjustment? i had a friend tell me one thing, but its not it, so yeah...where is it? pics may be helpful too. thanks.
Old Jan 1, 2010 | 02:28 PM
slomofo's Avatar
GDD Member
Default Re: where is my idle adjustment?
See your throttle cable? Cable is attached to the carburator via the throttle rotor (I don't know the proper name, I call it a throttle rotor).
Step on the gas pedal, throttle rotor moves butterfly open and closed..
Open the throttle, then close it. When you close it, you'll see that it stops on a little square piece of metal with a screw in it.
That screw is how you adjust your idle.
Sorry for the seemingly redundant instructions, I didn't know how else to explain it.
Old Aug 16, 2011 | 08:47 PM
G. Man's Avatar
I know this is an old thread, but isn't that just the curb idle adjustment? Shouldn't there be an actual idle adjust screw? I'm lost when it comes to my carb right now. I have two separate shop manuals, and they shed little light. I can't set the timing because I can't set my idle
cdmef
Jul 3, 2011 06:03 AM
theresyourproblem
Oct 4, 2007 09:28 AM
graphic
Oct 23, 2003 06:35 PM
CrOmEdOmEcHaMbEr
Feb 21, 2002 07:00 AM
GruvyTune
Aug 18, 2001 09:15 AM
