255 walbro and bosch 044 advantages?
Old Dec 31, 2009 | 11:15 AM
chrisdiz's Avatar
Default 255 walbro and bosch 044 advantages?
i have a very simple setup (gsr) je piston/eagle rods/Arp studs/1000cc precision inj./ precision 6262 turbo/ hondata s300/ 255 intank... would there be any advantages in running bosch 044 inline as well??
Old Dec 31, 2009 | 11:42 AM
92redhatch's Avatar
Default Re: 255 walbro and bosch 044 advantages?
Ya you can run one by the fuel rail. Be able to make more power then just one walbro
Old Dec 31, 2009 | 01:13 PM
chrisdiz's Avatar
I guess my question Is it worth buying for my set-up?
Old Dec 31, 2009 | 01:36 PM
MONSTERek4's Avatar
if ur not running out of pump then no how much power u making and what size injectors
Old Dec 31, 2009 | 02:48 PM
bettsbanger's Avatar
your intank should be fine, im assuming since your not sleeved you aren't going for more than like 400-450whp? if thats the case the walbro should do you fine.
Old Dec 31, 2009 | 03:41 PM
alpha's Avatar
The Bosch 044 will take the pressure off the in-tank Walbro. This is a great setup for 500whp - 650whp given the proper lines. Mount the Bosch 044 as close to the tank as you can
Old Dec 31, 2009 | 04:29 PM
extreme intent's Avatar
My single walboro intank got me to 490 hp on e85 and precision 1200 injectors. I myself am adding the bosch 044 to try for close to 600 hp but I'm already pushing it on stock sleeves
Old Jan 1, 2010 | 07:51 AM
chrisdiz's Avatar
how much better is the bosch/255 better then full-blown kit? is 500-550 hp to much to ask from stock sleeves, even with enough fuel.....??
Old Nov 14, 2010 | 06:40 PM
xjdmjunkiex's Avatar
how much power can be made with this if i keep my factory fuel lines, with the exception of the -8an line im goin to use from the filter to the pump, and from pump to fuel rail??
Old Nov 15, 2010 | 06:29 AM
twkdCD595's Avatar
Just a touch over 600whp here on a walbro/ bosch combo, all stock lines. -6an from the pump to the rail. Probably could have gone further but I was happy there. On gas, btw.
S2KP
Mar 11, 2010 08:52 PM
Davanca
Jun 22, 2003 12:06 PM
BoostedB18c5
Mar 21, 2002 09:11 PM
